Best stage 2-3 chip ? Torque over hp please :-)
I'm interested in getting the best chip for dark greens.
Can you guys come with some makers of chips? And if i'm really lucky even some numbers or a power graf
To me torque is king over max hp
so something like 300+ hp with as much low down torque as possible!
Cheers Kennert
Cheers Kennert
So I guess there is as many different opinions as there are cossie owners
BUT where is there some power graphs for compairing them?
who is known for doing the best torque curve?
the best chip you can get would be a live mapped one to your engine spec as that way its mapped 100 % to your car unlike the other off the shelf chips will only be mapped 40% to your spec
what about the Ahmed bayjoo 360 hp conversion ?
360 hp on a .48 3/4 sounds rather good to me, but again what is the torque?
The 360bhp on greens is bollocks ...340bhp MAX great conversion with the .48 but again i had an AHMED map and i found the COLLINS far wilder Do not underestimate Collins like many do...they been in the game since the beginning and the haters are the copiers
So are you saying that 350-360hp is not doable on a 0.48 ?
I think I've heared about an 360 conversion doing 357hs some time ago.
A guy called damean or someting like that!
Cheers Kennert
Cheers Kennert
gunship basically uses your Standard Injectors and T3 turbo to run 20+ Psi boost. This is something that iirc, Karl will only do if:-
a> Your engine is in very good health
b> He can map it and check it with your car - i dont think he would send you a chip out to run this boost.
DEYTUKURJERBS
i doubt hes daft enough to come from denmark for a gunship conversion and 300bhp when he can wack greens etc on there and be faster!
id just go for a chip from Stu myself, as long as the chip is specced for the engine, turbo, boost, etc your running, i cant see there being much difference between 1 and another off the shelf chip.
no way will you get 360 on greens and a t34 tho, thats just overreading rollers
Steve,
I dont think anyone would come to the uk for a chip tbh either, but the man asked, and i told him
If i hadnt, then he may of thought that Karl would just send him a chip to run big boost on a T3 with the standard injectors, which would've been wrong
DavidK
27-09-2015 02:55 PM
