best way to attach strut brace
as above really, its for my 2wd saph cossie. Is it best to screw or nut and bolt the brace to the turret. Screw would be easier but not as strong. If its nut and bolt how do u acess the turret from underneath as body panells and the springs are in the way ? Cheers luke
K***LMT
luke yu have to drop the suspension, jack the car up, put on axel stands, take the wheels off then undo the large nut at the top. only way you can really get to putting " nut and Bolt " in make sure they are thread lock type so they wont come loose etc. I gota do mine soon as only temp put the brace on with small nuts n` bolts and looks crap so got some nice allen key bolts M8 size with threadlock nuts.
luke yu have to drop the suspension, jack the car up, put on axel stands, take the wheels off then undo the large nut at the top. only way you can really get to putting " nut and Bolt " in make sure they are thread lock type so they wont come loose etc. I gota do mine soon as only temp put the brace on with small nuts n` bolts and looks crap so got some nice allen key bolts M8 size with threadlock nuts. ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Resident Wrestling Legend
look at his pics, then look at your turret, the bolt is fairly difficult to miss as it goes in that big hole the suspension pokes out of ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
pop the bottom ball joint, prise the hub out, then let the suspension drop out of the way once you've unclipped the brake caliper and the only thing left is the steering
you'll have to track everything back up agian when you put it together mind, and it's not a5 minute job so give it a weekend to make sure everything is spot on as you seem to be a bit novice with this mechanics thing
When I fitted mine I drilled and tapped the turret and used spring washers to stop it Coming loose. Was like this for a year or so until I fitted new shocks so put a nut on while they wher off never had a problem
Cheers daz
Cheers daz
