Plenum spacer
09-08-2011, 10:31 PM
Back in black!
Plenum spacer
Who does them and its 14mm im after so the injectors fit right isnt it?
09-08-2011, 11:29 PM
±§~Quadzackular~§±
Dont know who sell them? eBay? But im sure the smaller ones (10mm??) mess everything up for the fuel rail to the injectors and what-not! But the 14mm you just sit it on the other side.
When using these do you need a gasket on each side?
10-08-2011, 05:54 AM
Sponsor
Quote:
Originally Posted by
Eigdoog
yeh you need a gasket both sides
im sure hadland does these
10-08-2011, 05:59 AM
MK Motorsport
10-08-2011, 06:17 AM
Dont these add lag though ?
10-08-2011, 06:59 AM
10-08-2011, 07:08 AM
300+
10-08-2011, 07:20 AM
KSA-Cossie
Very slighty less lag or another 40hp?
10-08-2011, 09:51 AM
K***LMT
10-08-2011, 10:12 AM
Matt - you just missed the group buy for these too
10-08-2011, 10:16 AM
Danger Seeker
Got mine from MSD. Fitted cheap gaskets but they shit themselves when the boost was turned up to 30+ psi. Pair of Cometic gaskets fitted = problem solved.
10-08-2011, 10:19 AM
10-08-2011, 10:22 AM
Sponsor
KSA-Cossie
only on a t38
10-08-2011, 10:29 AM
Jay Cos
10-08-2011, 11:38 AM
±§~Quadzackular~§±
With these is it only about 450-500+ bhp you will see the difference? Ive got mine all part so might as well see if its worth getting while the question is about!
10-08-2011, 01:10 PM
Back in black!
Ok cheers
I'm guessing I NEED 1 if I want 450/60 on a 4x4 inlet was thinking of an aftermarket inlet but don't like the look of them lol+ it's extra money
Looks like Msd are the cheapest
10-08-2011, 01:36 PM
300+
R4N S S
defo go with cometic
gasket direct's NBR coated ones are far better and cheaper and look exactly the same as cometic.
10-08-2011, 01:59 PM
Think mines 17mm pretty sure it helped me on the 4x4 inlet t38 &greys
10-08-2011, 03:20 PM
rsmat
if you do order from them Matt - dont select the inlet gasket set as that works out a couple of quid more expensive than adding the items seperately
10-08-2011, 04:09 PM
10-08-2011, 04:19 PM
Sponsor
10-08-2011, 04:41 PM
300+
R4N S S
I did all mine a long time ago mate.
10-08-2011, 08:49 PM
Back in black!
R4N S S
Sounds about right
rsmat
never heard of them before mate Just placed an order they are quite cheap
R4N S S
Nice one Cheers
KSA-Cossie
Oi Kev he doesnt wear vests anymore......... hes still a cunt tho
Have Just ordered a 14mm spacer from msd, already have some bolts "in stock" will give the inlet abit of paint when its all here
10-08-2011, 09:07 PM
300+
Matt you won't go wrong with them... They are very good without the cometic price tagg
12-08-2011, 01:13 PM
any one got pics of before and after fitting the plenum spacer. So i can see what you mean about the fuel rail. TA.
12-08-2011, 02:26 PM
Back in black!
Remind me tomorrow and I will ad a pic here
12-08-2011, 02:58 PM
Danger Seeker
Heres an after pic, the fuel rail is just moved to the other side of the plenum.
Not got a before pic.
steve.rst
15-03-2016 08:01 AM
stephenb4506
33
02-10-2015 06:25 PM
mondeomark
28-09-2015 06:28 AM
IainRS1700T
25-09-2015 06:44 AM
timsrs
22
24-09-2015 08:14 PM
