HELP cvh on carb
Hi,
i am rebuilding a escort mk3 convertible
(post in the restorations section) i have misplaced the Fuel pump push rod.
Does anyone know the correct length the rod should be. ?
IT is a CVH engine running a Weber 2v tld carb. anyone out there know or can pop there's out and measure it? think this set up is normally in an XR2.
77mm is correct length or near enough i think but diameter is not 9mm it wont fit just for reference i made another at 8.5mm Dia and it fits nice to be honest i think it probably supposed to imperial in size 11/32 the most likely. but thanks for going out your way to check anyways.
![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
