I can use a Microsquirt to get my Fiesta 2.0 going can't I?
As far as I can see the inputs needed are all on the standard engine and intake manifold. If I make myself a loom from the Microsquirt/Fiesta/Focus engine loom, and use one of the basic maps to get it running I should be able to go from there?
Inputs being
power (+/- 12V)
air temp
water temp
maf/map
cps
tps
ignition live
Outputs being
injectors 1-4
spark timing
tacho if wanted
And I could butcher up the fiesta 1.3 relay block to run this? It doesn't sound that hard to be honest.
Inputs being
power (+/- 12V)
air temp
water temp
maf/map
cps
tps
ignition live
Outputs being
injectors 1-4
spark timing
tacho if wanted
Yes, but bear in mind you will only be able to run high imp injectors and you will need an external MAP sensor.
http://www.microsquirt.info/
mk3ste
17-10-2021 10:09 AM
Steve Escos
01-10-2015 06:57 AM
