4x4 sump help asap please:-(
Old 25-07-2011 | 07:50 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default 4x4 sump help asap please:-(
had to take the head off today, as the gasket blew when it was setup at ma developments on saturday , when it came to undoing the bolt on the back corner (turbo side) the bloody torx bit fell out of it's holder and dropped into the hole next to the bolt and ended up in the sump, now im thinking i maybe screwed. its on a 4x4 cos, and i now from past engine probs that everything has to come off just to get the sump off, the engine is coming out after ford fair for rebuild and the car is having a respray, so i cant be arsed to take the bloody thing out twice in a short space of time, will the torx bit be alright???? or will i mangle the engine. advice would be received very gratefully.
Old 25-07-2011 | 07:59 PM
COLEYST200's Avatar
COLEYST200
Its one of them that i would not wont to put my name to but i have stripped a yb befor to find a valve stem seal in there
Old 25-07-2011 | 08:35 PM
OrionRST200bhp
i should of kept my 2wd:-(
Old 25-07-2011 | 08:43 PM
combivan's Avatar
combivan
u need a magnet on a stick got my collet out the sump when i did valve stem seals with the head on and did the same thing
http://www.ebay.co.uk/itm/5lb-Magnet...#ht_2721wt_989
Old 25-07-2011 | 08:46 PM
pee vee's Avatar
pee vee
took the sump off my old 4x4 cos, and found the very bottom of a dipstick in there!
god knows how many years that had been in there, or how it came to snap off in the first place
herbcosworth's Avatar
herbcosworth
herbcosworth
put a magnetic plug in it mate see if that gets it out or an extendable magnet put it down the hole it fell down?
Bailes1992's Avatar
Bailes1992
Isn't there a strainer in the oil pump anyway? You should be fine.
Old 25-07-2011 | 08:47 PM
OrionRST200bhp
i tried that in the big hole where it fell down but half way down the hole it comes to a stop.
Old 25-07-2011 | 08:54 PM
botters's Avatar
botters
competant bodger
it cant get sucked into the oilpump itself because it will be too big to get past the strainer but i wouldnt want something of that size in my engine as there is every chance it could partially block the strainer
to be fair if you allready have the head off its not a big job to just lift the block a bit to drop the sump down
OrionRST200bhp
i thought it maybe allright as long as it hasnt fell onto the baffle plate. surley theres noway of it getting caught up amongst the big ends. its quite weighty aswell so i would of thought it would just stay at the bottom of the sump. i doubt even the pick would suck it up...... if you have noticed im trying to make excuses so that i dont have to drop the entire engine.
Old 25-07-2011 | 08:56 PM
OrionRST200bhp
can i lift the block a bit can i just to drop the sump a bit?
Old 25-07-2011 | 09:10 PM
Steve Cooper's Avatar
Steve Cooper
i would leave it in there, otherwise you have got the horrible job of trying to refit the sump in situ. but i no nothing so probably wouldnt take my advise lol.
Old 25-07-2011 | 09:24 PM
OrionRST200bhp
im tempted to leave it as i have to strip it all over again in 3 weeks anyway.
Old 25-07-2011 | 09:31 PM
RONNIE AMIS's Avatar
RONNIE AMIS
dont listen to him, he would try and fix it with cable ties
i wouldnt risk it mate, you'd only be kicking yourself if it done some serious damage
Old 25-07-2011 | 10:47 PM
Brendan's Avatar
Brendan
struggling with reality
have you thought about trying a magnet up throught the oil drain?
01-11-2015 07:53 PM
07-10-2015 01:56 PM
gcfcos
59
06-10-2015 06:04 PM
Iain Mac
30-09-2015 10:39 PM
youngben
27-09-2015 10:37 PM
Quick Reply: 4x4 sump help asap please:-(
