ST200
Old Jul 22, 2011 | 09:56 PM
Colin Brooker's Avatar
Colin Brooker
Unhappy ST200
I am having terrible trouble finding head gaskets to fit mt Mondeo ST200 every set i have bought have been wrong, I have even been to the Main dealer and still they do not match my oil way layout. the engine has a Plaque with "YB" on it every one tells me look for LCBA or various other letter combinations but none are on my block.
Anybody know how many versions of the 2.5 V6 that ford fitted.
Trouble is the Engine was replaced back in 2003, and the garage that fitted the replacement said it was a direct replacement, but I now have my doubts.
I believe the engine may be from a Cougar as I have seen Gaskets advertised on ebay that look exactly the correct layout with an engine code LCBB but when I oredered a set they sent me an LCBA and they were the same as every other set that I have ordered and sent back.
Help!!!!!
Regards
Colin
Old Jul 22, 2011 | 10:21 PM
stuboy's Avatar
stuboy
Help!!!!!
Regards
Colin
searched lcbb looks lika cougar
http://cgi.ebay.co.uk/Ford-Coolant-T...ht_2302wt_1008
found this..
Cougar 2.5 ... 1998-01 ... eng code LCBA/C ...
Cougar 2.5 ST 200 ... 2000-01 ... eng code MABA ...
Old Jul 22, 2011 | 10:26 PM
Chaz888's Avatar
Chaz888
ok colin if its an st lump it will have yellow bands on the cam,s and I believe a raised center on the pistons for the higher comp spec of the st lump and very smooth intake ports (extruded honed),also a yellow tab spot on the flywheel,also the codes I have not found on the block its on the cam chain cover .
Old Jul 22, 2011 | 10:50 PM
Colin Brooker
The pistons have definitely got raised centres I will look for the other markings tomorrow, Thanks for your help
blakey100
Aug 4, 2015 08:17 PM
dubster53
Ford Mondeo Including ST
Sep 24, 2007 08:10 PM
xr-stu
11
Sep 10, 2006 09:04 AM
ster
Feb 5, 2006 06:30 PM
