DPF replacement pipes - to bin off the particulate filter, where from?
My friend has just bought an 07 plate BMW 325d and I'm looking for an 06 on 535d BMW.
Both of us will be getting remaps from Chip who is an Evolution Chips installer for our area. One of the option we both want to take up is to bin off the DPF, as my friend's car will do a lot of short trips and I just don't want the bills DPFs can bring.
So we both need DPF replacement pipes - like decat pipes as far as I can tell.
Who can supply them and how much?
Seen a few on Ebay, but they're silly money and usually include "tuning boxes" which we know to avoid.
Are the replacement pipes just like a decat pipe? In which case maybe we'll get a local stainless exhaust place to make some up.
Anyone know more about it?
Si
Si
It will depends what the chip is going to be telling the ecu si.is the chip going to tell the engine ecu that it hasnt got a dpf if thats the case u just need a straight through pipe and bin the pressure sensors and temp sensors off, or is the chip going to trick the ecu and give it made up dpf figures and id imagine if thats the case id imagine just as focusv8 has said as you will still need the sensors
Also it is likely to be a fail on the mot in the future, even if the car meets the emission limits.
The regs are changing to something along the lines of "catalyst/dpf removed"
All the sensors still need to be in place as they may be used for other purposes and the ECU will flag fault if they do not work or are removed.
Lots of people just remove the guts from the standard exhaust and then refit it, aftermarket removal pipes can be hard to find.
would the cars still pass a normal MOT with the DPF mapped out?
what I mean is can you take the car anywhere for an MOT or will need to be a 'friendly' mot man?
no vosa could only do you if your emissions were illegal,
iv managed to trick the ecu before into doing a regeneration to try and save a customer some money and it work a treat
our DAF trucks are constantly showing the DPF warning light on the dash.
some times they have to go in as they wont go past 30mph, they are such a shite design these DPF filters
There was some serious concerns over the paticle sizes allowed though dpf units Shen I worked at vosa, they say the particles that come through are so small they can br absorbed through the skin and cause cancer and can be fatal.
It's strange how things go full circle, the emissions are now so tight they produce dangerous emissions, where as the old particles were so big they would bounce up the road, but not kill anyone,
It's a crazy world.
The dpf is nothing but a filter in ths exhaust to catch diesel particles, when the filter gets blocked it's burnt clean by increasing egt.
It's a crazy world.
yes we do james i work for a vauxhall in dealer but as im sure youl know most systems iv come across anyway if they have any dtc's in the ecm it will not carry out a static regen.and on this one occasion it had a number of codes stored wich the customer didnt want anything doing with and as they were present codes it wouldnt carry out a regen so i was able to trick the ecu into letting me do one i was quite pleased with myself
thats completely mad, whats worse is the general public who buy these cars based on doing their bit for the enviroment are unaware of the dangers they possibly produce to them and their families
ELASTIC BAND
Screw the environment issues, they should come with a big warning sticker, saying if you live in any traffic congested area then this vehicle is not suitable for you
Does a man (or woman or child) with a sweeping brush run behind the vehicle collecting the particles or do they just blow out into the atmosphere?
Remind us again of the whole point of the DPF.
Why don't they make the filter removable from the housing like air filters then they could be easily changed and would be considerably cheaper.
The company Transits I drive are specified without DPF.,
Just looked on that site and what a fookin rip off and most dpf iv put on cars have been between 4-800 pounds.
Iv also took a dpf off before and pressure washed it out for about 2 hours and have to say that worked dont think id pay 350+vat to have a dpf cleaned
NC53
13-09-2015 03:05 PM
325d, bin, bmw, car, dpf, filter, focus, ford, mondeo, navara, particulate, pipe, pipes, regeneration, repacement, replacement, static
