Ford Focus 1999 - Reverse Light
Can someone please help, my reverse light does not work, I have checked the bulbs and they are fine.
Not sure what the symbol is on the fusebox.
Thanks in advance
Rav
Thanks in advance
Rav
dont think reverse light is fused tbh.easiest way to check if its switch is unplug it from front of the gearbox,bridge a wire between terminals then switch ignition on.if it comes on then the reverse light switch is faulty.also check the bulb holder connections as these get grimey too
