CVH Guru's...300hp from 1600cc...your views??
Old Feb 12, 2005 | 01:11 AM
bassboy's Avatar
bassboy
Default CVH Guru's...300hp from 1600cc...your views??
Hi peeps, just wondering what you think it would take for a 1600CVH to produce 300hp...at the moment, on my shopping list is:
+.5mm MAHLE pistons
custom length steel rods
new pumps
stage 3 head
EFI setup
T34 turbo (or can one recommend another turbo?)
Mongoose 3" bore exhaust
Pro Alloy intercooler
Kent CVH35 cam
stage 2 g/box
AP Racing clutch
what other big bits am i missing?
does a T34 have to be used or is there a GT series replacement?
will FRST management be adequate for this?
thanx
bassboy
Old Feb 12, 2005 | 01:14 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
an extra 400cc
Old Feb 12, 2005 | 01:17 AM
bassboy's Avatar
bassboy
Dave...i have a 2L 16v sitting in the garage just wondering what it would take for a CVH to get to 300hp
bassboy
vroooom ptssssh
It Wasnt Me!
p.s. and a fucking shitload else
*edit* on a seruious note, that spec above are pretty much the basics, but imo a 1600cvh will never reach a genuine 300bhp@fly. honestly.
Old Feb 12, 2005 | 01:18 AM
Escy's Avatar
Escy
i'd use a GT28R to get 300bhp. thats what i have on mine and its 300bhp. good for 330 too
Old Feb 12, 2005 | 01:19 AM
mattbibs's Avatar
mattbibs
for starters im guessing more than a stage 3 head!!
Old Feb 12, 2005 | 01:20 AM
vroooom ptssssh
It Wasnt Me!
Exactly
Old Feb 12, 2005 | 01:22 AM
bassboy's Avatar
bassboy
wats above than a stg 3 head??b and wats the differences between the 2?
bassboy
Old Feb 12, 2005 | 01:26 AM
vroooom ptssssh
It Wasnt Me!
theres no official stg3+ head cos not many ppl need them. .
Old Feb 12, 2005 | 01:30 AM
bassboy's Avatar
bassboy
hmmm...maybe....but at the end of the day...a stage 3 generally consists of bigger valves (the biggest you can fit in the head) and some serious porting and polishing...so why wouldnt this be adequate?
A standard head can flow 250hp (well thats what Gadgets old car did) on EFI and a T3 IIRC so increase the airflow into the head via bigger valves, more fuel also, and a bigger turbo to create more boost...would you not arrive at 280-300hp?
bassboy
T28 RST's Avatar
T28 RST
Ok then
What boost are you planning
Old Feb 12, 2005 | 01:32 AM
bassboy's Avatar
bassboy
also i forgot to write the flow of the head is important to...i.e the path the air/fuel take into the cylinders which will play a big factor to but say if thats done VERY VERY well....or lets just say i bought a stage 3 head of Karl...is it still a dream??
bassboy
Old Feb 12, 2005 | 01:34 AM
bassboy's Avatar
bassboy
T28 im not too sure....about 24-25psi on a T34 would be good...maybe more if the engine allows....the idea for the custom rods are to reduce the compression ratio lower yet keep as much 'meat' on the piston as possible
things on the EFI side would be like the biggest possible injectors, everything renewed, custom map etc etc
bassboy
Old Feb 12, 2005 | 01:38 AM
bassboy's Avatar
bassboy
The engine must once again come apart and the fitment of steel con-rods and stronger pistons is now essential.. Coupled with all the modifications carried out up to stage 5 a hybrid Garrett T34 is now fitted with a Cosworth based exhaust housing. A custom exhaust is now required, and coupled with either a larger 5th injector or a 5th and 6th injector the boost is now raised to 25psi. The fitment of an uprated gearbox is now essential. At this level there are many additional minor modifications required to cope with the power but this can be advised at the time. Power levels are now at 300bhp.
taken from Karls site...he also says use a Stage THREE head, decent intercooler, cam, raised rev limiter,lightened and balanced bottom end, steel rods, T34, 25psi boost
so will a stage 3 head do the job or not??
bassboy
Old Feb 12, 2005 | 01:39 AM
vroooom ptssssh
It Wasnt Me!
no, that wouldnt be adequate still, i dont know how to explain it as im not that knowledgable but basically NO. and you cant decide what boost until you mapp it, you can aim for a figure to work out what sort of CR u want but i dont think u'll know what boost is best untill map time.
theres a whole host of things missing from that spec you'll need as a base aswell.
Old Feb 12, 2005 | 01:44 AM
bassboy's Avatar
bassboy
i know i cant decide what boost i can run as every engine is different hence me saying whatever more the engine will allow...but i know CR will be around 7.6 maybe 7.5 but i will do more research into that as i dont know many people running the setup i have just described...
the spec i gave was just a general one of the main parts you need...i have listed a turbo, intercooler, box, bottom end plans, head plans and a VERY general fuelling setup - well basically EFI off a FRST
so vrooom...if i decided to go for a ZVH with a 2L bottom end...would i hit the figure then? i remember John hitting 28xbhp cant remember exact figure...was that down to the head not being able to flow enough air or something else?
not a dig by the way..am just generally interested as i have heard a few people talking about 300hp CVH's
bassboy
Old Feb 12, 2005 | 01:46 AM
bassboy's Avatar
bassboy
would things like custom inlet manifolds and exh manifolds come into the equation to?
bassboy
Old Feb 12, 2005 | 01:49 AM
vroooom ptssssh
It Wasnt Me!
Ive heard of 300bhp CVH's too, but they generally fly past in the wind and that's all u hear. . .
Im no expert, far from it, but ive never known on a GENUINE 300bhp CVH, i know of a 268@wheels ZVH which may possibly make more power once its completed, but thats about as much as i can expand on that. I know very little about ZVh's so i cant help on the potential figures sorry mate.
But whatever the spec you use i hpe you get what you want from the engine, i'll let the proper technical people take over from here
Old Feb 12, 2005 | 01:50 AM
vroooom ptssssh
It Wasnt Me!
bassboy
Very much so
Old Feb 12, 2005 | 01:51 AM
bassboy's Avatar
bassboy
lol...thanx dave well my choices are between a T34 ZT or a T34 CVH (have a look in the escort forum and it'll be explained better there lol)
bassboy
Old Feb 12, 2005 | 01:52 AM
bassboy's Avatar
bassboy
any one got any pics or info about trick manifolds? ive seen the tubular exhaust manifold on karls site...any info about the inlet? or is it a case of TB's?
bassboy
Old Feb 12, 2005 | 01:54 AM
vroooom ptssssh
It Wasnt Me!
no probs mate, tbh i think Zetec turbo would be a far better option to get the desired power your after good luck.
Old Feb 12, 2005 | 01:55 AM
bassboy's Avatar
bassboy
its just the money as i know i can do the CVH reletavily cheap in comparison
bassboy
Old Feb 12, 2005 | 06:51 AM
Rick's Avatar
Rick
oh dear oh dear
Old Feb 12, 2005 | 07:34 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
A CVH can produce 300bhp with a decent head and engine build.
1597cc with a comp of 8.2:1 T35 with 24psi produced 284bhp on Ants engine. He has taken the head off to replace the std ford gasket for a uprated head gasket which will be able to put up with the stress of high boost. (It was wire rung before)
At the same time he has had the ports matched in flow and size compared to the inlet manifold which has only been matched and not ported.
Ant is now getting the car ready as he will be driving his new car (& engine) to Ibiza in the summer apart of the www.extremerallies.com. event
When i have finished the work on his engine we are hoping for 300+bhp with a 1600cc and hopefully a new map on dizzyless
HTH
Old Feb 12, 2005 | 07:43 AM
Oli's 1.9 is over 300bhp
Chadley's 1.6 is over 300bhp
Tim's 1.6 will be over 300bhp
Old Feb 12, 2005 | 07:50 AM
gus's Avatar
gus
300bhp is poss then
Old Feb 12, 2005 | 08:20 AM
Jon ERST S2's Avatar
Jon ERST S2
Mine was 288bhp. (ZVH)
Head was ported and had wasted stem valves (standard size)
bassboy
Old Feb 12, 2005 | 08:41 AM
bassboy's Avatar
bassboy
dingy...what sort of advance on the timing do chad, oli run? have they been on a RR or anything to prove they are actually over 300hp?
again, please dont take it as a dig...im just curious as to which route to take...cvh or zetec...as after chatting to chad when i went to see him...he reackons CVH's drive alot better than ZT's
bassboy
Old Feb 12, 2005 | 08:43 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
PMSL. Mine must be close.
Old Feb 12, 2005 | 08:49 AM
adamS2RST's Avatar
adamS2RST
Was gunna say, oli, tim etc are 300
Old Feb 12, 2005 | 08:52 AM
bassboy's Avatar
bassboy
christian...wat turbo do you use? any trick manifolds?
bassboy
Old Feb 12, 2005 | 08:56 AM
adamS2RST's Avatar
adamS2RST
Bass, u got this months PF? The Daddy thrash is in there and christians & Oli's specs are in there....
Old Feb 12, 2005 | 08:57 AM
bassboy's Avatar
bassboy
oh yea...DUH LOL...but IIRC all it says is GT series turbo...which GT turbo is it? lol
bassboy
Old Feb 12, 2005 | 09:44 AM
DazC's Avatar
DazC
So what makes people think a CVH can't produce 300bhp?
What reason?
Old Feb 12, 2005 | 09:46 AM
adamS2RST's Avatar
adamS2RST
It can....can't it? ....
Now where is that pic of the hobnobs and cup of tea
Old Feb 12, 2005 | 09:49 AM
Matt's Avatar
Matt
LOL
a correctly specced cvh head can flow way more than 300hp
cc is irrelevant for max hp
Old Feb 12, 2005 | 09:53 AM
DazC's Avatar
DazC
Originally Posted by Matt
LOL
Exactly why I want to know why people think a CVH can't produce 300bhp....
Old Feb 12, 2005 | 10:21 AM
Lemon S2's Avatar
Lemon S2
Cpt Scarlett from here series 1 is a 1600 and that produced 290bhp at 1.5bar and 319bhp at 2bar so 300 bhp from a 1600 is achievable, I'm not gonna give his spec as not my place to do it but the car is off the road at the moment having a few more bits done to it so hopefully will see more from it in the next couple of weeks
