Transit specialist in NW ??
Anyone know anyone good with mk6 transits in NW ?? Having a nightmare with mine trying to get it running and could do with someone glancing over it with fresh eyes otherwise sticky and myself may not be coming to coombe on say
Try a set of injectors like I said on the phone Kev. I can always get our workshop to look at it but you'd need to drag it to Preston and you'd be paying Ł35 p/h labour! We'd do a leak back test on the injectors before removing them though (measure how much comes out the leak off port on the injector).
wont start mate had pump recond, changed filter head, sender unit, plastic pipes and new crank sensor bleeds up fine but wont start and no management lights come on but will run once in a blue moon for about ten mins then die like fuel probs
They can suffer with broken crank sensor wiring where the loom drops down near the water pump, try wiggling the loom while someone else cranks it, also, how many miles has it done? They suffer with timing chain tensioner faults, this causes the chain to slacken off slightly when left for a long period of time, at best, this will stop it from starting because the cam/crank sensor lose sync, at worst, the valve timing jumps and scraps the head.
Karl
Haha, that's my theory out the window then lol. Have you taken the crank sensor out and looked at it to see if it's covered in meatl swarf from the flywheel?
If you crack the injectors off and crank it, is there much fuel at the injectors?
Also, what's the main electrical connector like on the back of the pump? A bad connection there can stop it from starting, and when it's running, vibration from the engine can cause it to cut out, had one like this a few years back, took me ages to find out why!
crank sensor was changed yestersay and bell housing/flywheel was ok
seems to be getting plenty of fuel from injectors
Will check plugs/wiring today but not seen anythin there really
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
