Any land rover boys on here?
Are you any good on engine problems just need a second opinion .... It's building up lots and lOts of presure so much so that oil is leaking out of the rocker cover ..and when you take of the oil filler cap when running it's like a steam train the amount of steam coming out, would you say it's head gasket? Ad it could be pistons rings couldt it ,,it does puff out abit Of blue smoke when cold but other than that it's fine no mocks or no taps?
its okay i edited it. lol i had one like that last week, (turbo, crack it the piston, rings and head gasket all at once.) engine change and de gunk in less then 12 hrs start to finninsh. and it was (waterised + winterised) = absolute cunt.
It has a little bit of oil in it just looked then, also ..the filter Is clean no oil ?
When I broke mine the lad who had all the underbody protection had his disco stolen and stripped not long after.
A friend of mine spent real mega money building a challenge 90 only to sell it straight away cos he was shit scared of it being stolen.
Gavin.
Gavin.
Yeah it's nuts epcialy round
these ways ( Liverpool), I bought one spent a few grand getting it to how I like it, had it booked in to get an alarm put in...two nights before this it got stollen!!! Drove it straight through me garden bushes !!! Tears came out
they are easy enough to do.
is there anything where it shoudn't be? oil in water?
it was in a barn, using a hi-ab. lol we was only supposed to be backup drivers if the engineers when over there drivers hours. (doss week.) but then we done to engines and 18 hr days.
next up on the list to check is the crank case breather. take off the black box off the rocker cover and blow down it with an air line if you can to see it ifs blocked.
Ok il try that tommorw, what If it is blocked? Is it no way a head gasket problem ? Bearing in mind I only got it yesterday and trailered it home so not had chance to see if the water goes down much ?
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
