Amplifier advice ?
Old Jun 25, 2011 | 08:23 PM
matthewsimone's Avatar
matthewsimone
Default Amplifier advice ?
Possibly in wrong section but here goes nothing !
Is it possible to wire up a small amplifier in my S2 but still using my original head unit ? ive already worked out a way to overcome the remote lead issue by just adding a switched live from the ignition but im struggling with the input side as obviously my 25 year old stereo does NOT have rca outputs on it but i was told a while ago by someone that there is a way around this by using speaker outputs maybe? only looking to get a very small amp that can be concealed behind dashboard to hopefully give my original stereo a bit of a boost! have also uprated the original speakers with some better items but kept standard size etc for originality
Any advice would be much appreciated as usual
Linky below of similar to what im thinking of
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Old Jun 25, 2011 | 09:59 PM
cjwood555's Avatar
cjwood555
Easiest way if you're not into electronics is to buy the autoleads converters.
Chris
Old Jun 25, 2011 | 10:10 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
that, having a high level input should work fine, but, bear in mind, it only has output for 2 speakers so you would have to split that to get front and rears working
Old Jun 25, 2011 | 10:21 PM
Rob Virgo's Avatar
Rob Virgo
Recon it would be better to mount a modern high power cd head unit in the gb or hidden under the dash, can get wired remotes so you can use it while hidden.
Upgrade seekers in doors(2ways) and your sorted
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
