engine sensors
Old Jun 19, 2011 | 03:00 PM
wide ka's Avatar
wide ka
Default engine sensors
hi all,
im building a turbo zetec engine for my kit car, im runningomex 600 and a race technology dash 2, what sensors would most people be looking at running?
i have the normal water temp air temp oil pressure and oil temp, and boost i think i should be able to sort, is exhaust temp a good idea to have to keep an eye on? or what would you guys recommend
thanks
Old Jun 19, 2011 | 03:15 PM
GaryHurn's Avatar
GaryHurn
you will need
tps
map sensor
coilpack
crank sensor
coolant temp
inlet air temp sensor ( one with a quick sample rate saab turbo sensor i used on my nova)
extras
boost control solenoid
egt gauge ( omex 600 doesnt have input for egt seperate gauge would need to be used)
wideband sensor for closed loop fueling should you wish
Old Jun 19, 2011 | 03:23 PM
wide ka's Avatar
wide ka
Originally Posted by GaryHurn
you will need
tps
map sensor
coilpack
crank sensor
coolant temp
extras
thanks, im using the interface lead from omex to dash so that will pick up the normal engine sensors,
i will want a wideband at the least ill have a look at the exhaust temp sensors
Old Jun 19, 2011 | 07:55 PM
I'd use all the normal engine sensors as it's a road car, personally I wouldn't bother with EGT.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Derek Burleigh
Sep 16, 2015 06:27 PM
Tim Wharton
Aug 30, 2015 05:46 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Zoggon
Aug 10, 2015 10:39 AM
