Brembo Calipers under 16" wheels?
18-06-2011, 01:15 PM
Has anyone fitted Brembo calipers under 16inch wheels?
What car do i need the calipers off? (Focus RS, Pug coupe, Alfa etc???)
What size discs will be needed?
Currently got wilwood calipers with 300mm discs and bells but wanting to change to Brembo's.
18-06-2011, 03:23 PM
I'm currently attempting to get Evo brembos and 330s under some compomotives
18-06-2011, 03:39 PM
They 16 inch comps? If so mine are also comps. How u doin so far?
18-06-2011, 03:48 PM
Reckon it should go but gunna be millimeter close and might need a small spacer behind wheel
18-06-2011, 03:55 PM
What shape eve they off and what discs you using?
18-06-2011, 04:22 PM
Christian Major manged 330mm AP disks with Focus RS brembos under 7x16 pro race2 team dynamic wheels on his RST.
18-06-2011, 04:24 PM
Ive got a full set of brembos from my evo 7 if any one is interested.
18-06-2011, 04:26 PM
18-06-2011, 04:27 PM
And focus rs fitment discs
18-06-2011, 04:36 PM
Quote:
Originally Posted by
AquariousRS
What is the clearance on comps compared to team dynamics though? Are comps normally good clearance?
19-06-2011, 03:22 PM
19-06-2011, 06:41 PM
i could help you with some alfa romeo GTA calipers (i think that's what they are), they are red in colour. Will double check if interested
19-06-2011, 06:45 PM
http://www.capriracing.co.uk/newbrakes.htm
have a look m8
the calipers are bmw
stuart
19-06-2011, 06:50 PM
Cheers stu what the calipers off and what car are the discs off?
19-06-2011, 08:24 PM
Ops just seen they BMW lol
19-06-2011, 08:36 PM
The fiat coupe 20v turbo had brembos with 16 inch wheels if that helps.
20-06-2011, 06:02 AM
20-06-2011, 08:37 AM
Bulletin Board User
Standard FRS calipers & discs behind 16" Superleggera. I had to machine the top face of the caliper to make it work, and even then there wasn't much clearance.
Those Brembo's are chunky calipers and really need 315-320mm discs behind 16's, or alternatively use an AP caliper which tend to be smaller overall.
20-06-2011, 02:53 PM
excursion - what car is that on?
20-06-2011, 03:06 PM
I have frs cailpers in black with pads if any good
20-06-2011, 03:32 PM
Bulletin Board User
mattseries2
Fiesta Mk3
20-06-2011, 04:52 PM
How do the calipers mount to the hubs? Do u need brackets made?
20-06-2011, 06:09 PM
Bulletin Board User
mattseries2
Yes I had to make up some alloy brackets.
I think people do sell steel versions on eBay from time to time.
20-06-2011, 06:11 PM
Bulletin Board User
20-06-2011, 07:39 PM
It says for BMW brembo's... Are the focus holes the same?
20-06-2011, 09:15 PM
I'm running under 17's with standard FRS Brembo 324mm discs.
20-06-2011, 09:32 PM
they fit under my comp frs quite easy just need to shave a bit off the top of the calliper. the problem you will face is more to do with the off set of the focus rs disc as they dont have much off set and are very close to the back of the wheel
20-06-2011, 09:36 PM
What size are your comps? Mine have a large offset so should be ok.
20-06-2011, 09:46 PM
yatta
21-05-2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
focus2351
09-09-2015 09:33 PM
Adam Graham
06-09-2015 06:04 AM
cossirob
03-09-2015 09:17 PM
16 ,
20v ,
315 ,
320mm ,
brakes ,
brembo ,
caliper ,
calipers ,
car ,
clearance ,
colour ,
coupe ,
fiat ,
mk3 ,
mondeo ,
shave ,
wheel
