intake pressure test????
Old Jun 14, 2011 | 09:18 PM
creator's Avatar
creator
Default intake pressure test????
where can i get an intake pressure tester kit from? anybody know
cheers
Old Jun 14, 2011 | 09:27 PM
RickyLee53's Avatar
RickyLee53
What is it your trying to do?
Make one?
Old Jun 14, 2011 | 09:29 PM
creator's Avatar
creator
not necceserily rick no mate i just want one,we have got a really good one at work but was ££££ and i only really want it for my own personel use at home on my cars and cars i help build at home
Old Jun 14, 2011 | 09:31 PM
RickyLee53's Avatar
RickyLee53
Have you got a compressor?
Old Jun 14, 2011 | 09:38 PM
creator's Avatar
creator
not at home mate no
Old Jun 14, 2011 | 10:00 PM
studabear's Avatar
studabear
Sure its been mentioned on here before,
iirc some thing to cover the intake on the turbo once the air filters removed, with a tyre valve fitted into it.
Old Jun 14, 2011 | 10:06 PM
creator's Avatar
creator
yeah i think your right stu but i dont want anything pikey that might leak itself causing headaches lol
Old Jun 14, 2011 | 10:18 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
You need one of these like I used on my Escos below:
I had a good friend of mine make it up for me, you'll need a lot of air to keep it all pressurised for any duration - I have a 50l compressor.
Very handy for leak detection and fixing - some of the leaks I had were like howling gales. Worryingly two were from failed / nicked injector seals, and one was from a Samco hose joiner that wasn't that well installed.
I now only have very minor leaks from a couple of bolts on my plenum, which just need some thread sealer on them.
Use a squirty bottle with washing up liquid and water in it, and spray around everything linked to the inlet side - plenum, TB, Inlet manifold and boost pipework to help to find the leaks.
Si
Old Jun 14, 2011 | 10:20 PM
Si B's Avatar
Si B
Oh don't whack in more pressure than you plan to run - I used 40 psi max testing mine. At 45 psi by accident, the pipe blew off the turbo and whacked me in the bollocks while I was trying to look at the pressure indicator
Old Jun 14, 2011 | 10:28 PM
ASHCOSSIE's Avatar
ASHCOSSIE
do u have to remove downpipe and seal rear of turbo too ?
Old Jun 14, 2011 | 10:51 PM
Si B's Avatar
Si B
Nope, not to check the inlet side at least. Just crank the engine round till all / most of the inlet valves are shut. I didn't know how to do it scientifically, so just rotated the engine by hand till the air leaks stopped and the pressure gauge started to climb
Then whacked in the air to 40 psi and started tightening stuff up!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
