misfire on rs turbo
Hi wondering if anyone can help me i was out in my escort turbo just on the carrageway car started misfiring bad and sounded like a subaru i thot it was the headgasket no signs of milky oil and water seems ok tho. its chapping a bit at top end this has happened before but it just went away when i drove the car cars cooling down at the moment any ideas what this can be cheer
To be honest with you im kinda new to it only my second rs mate i know a bit about them but im dont know whats happened with it il check plugs and leads. This happened before i just let the car cool down drove it and the chapping went away and it ran fine??
Stuck lifter possibly?
I had the same experience, when i went on the dual carriage way and put my foot down one of the lifters kept sticking, turned out it was badly domed so i changed it and it never happend again..Few things you can check for, Hope you find the problem soon though.
Joe
Joe
I thot about the lifters when i heard the chapping but would that make it misfire quite badly the engine has just been rebuilt and is very quite this only happens when its hot as well??
sounds like you could so with getting the car to an RS turb specialist for a checkover at the very least mate. why guess and randomly start swapping parts when they will KNOW what the issue is and just change any parts that need it
First what is chapping lol?
secondly glad it has sorte ditself (for now), as mentioned above a faulty lifter not opening the valve properly. Might be a good time to get a new set of good quality lifters (and maybe a cam while your at it)? Not a hard job, can be done without removing the head. Also give it fresh oil and make sure you run the cam/lifters in properly. Ideas on this vary slightly but the main thing is to avoid idle for the first half hour and use plenty of lube (that's what she said!).
Good luck mate
Good luck mate
Thats wat i think it is mate dodgy lifter took it to a mate hes had them for years thats what he thinks as well il try new cam and lifters oil change see how i get on.
thanks alot for the feedback
I had a K reg, 1.4 orion cvh with a blocked rear breather that somehow used to stop the lifters functioning correctly. I presume crank case pressure was stopping oil getting to top end???
Now you've described what happens this makes sense, I told a lad I knew what had happened when my car broke down, he said pull the breather pipe off that runs from rocker cover into the block and check the stub on the block is clear, or more so he told me mine would be blocked, he was correct. Worth checking out for the time it takes, I unblocked mine and fitted new lifters and it was alright for a months till I got rid.
I hated the car so when I unblocked it I just pushed all the crap into the sump![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
If your is blocked I would remove the sump, as you don't want all the crap floating about
