chargecooler kit
Old Jun 8, 2011 | 02:45 PM
Thanasis's Avatar
Thanasis
Default chargecooler kit
Hello all,what do you think about this kit for sierra cosworth ?thanks
http://cgi.ebay.com/ebaymotors/TYPE-...mZ110575319199
Old Jun 8, 2011 | 03:03 PM
chaffe's Avatar
chaffe
Turbocharging Technician
Chargecoolers are a compronmise really, and are not as good as intercoolers, they are suited for tight spaces. Why would you want to put this on instead of one of the many reputable intercoolers? im sure this kit is fine though in saying that
Old Jun 8, 2011 | 03:05 PM
Joshy's Avatar
Joshy
Dreamer
as above, when there are some very capable intercoolers available for bargain prices for cosworths, I dont see the point of going to a chargecooled setup
Old Jun 8, 2011 | 03:07 PM
sierrafun's Avatar
sierrafun
with that you have 0 lag
Old Jun 8, 2011 | 03:11 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Everyone here will slag chargecoolers off, but I'll be honest and say I've never looked into comparisons against each other so won't comment. All I will say is I've run a Pace chargecooler on my S1 for 12 years and never ever had any issue with it at all. Car pulls like a train no matter how warm the temparerature is outside.
Old Jun 8, 2011 | 03:16 PM
Joshy's Avatar
Joshy
Dreamer
i have no problems with chargcoolers... i would consider one myself is i ever went forced induction on my nova puerly because of the lack of space, its just that a cosworth is well suited to an air to air intercooler as it is so the added complications of a chargecooler is often unnessasary.
@ sierrafun.. what makes you think you would get no lag with a water to air intercooler? the type of cooler has very little effect on lag and only then because of the volume of the intake system...
Old Jun 8, 2011 | 03:23 PM
R4N SS's Avatar
R4N SS
i didnt think coolers affected lag that much
Old Jun 8, 2011 | 04:12 PM
lacey's Avatar
lacey
There is lag with a cc that is due to the size ref how much , they are shit hot on drag cars as they are cool befor they set off and there big which they need to be to work , I worked St pace for many years and I tested a cc on my cosworth I also had a 500 cooler in it at the same time and all the temp reading were saying that the cc made no different from being turned on , but having said that on the s1 and s2 they worked very well and how well they work is due to cc size and the cc water rad size so as much as someone many say there shit this is not true as you just need to be sure it right for your cars needs
Old Jun 9, 2011 | 10:13 AM
sierrafun's Avatar
sierrafun
in greece we cut the rs 500 intercooler t35 set up engine .we reduse the lag like that .the turbo was press air from 2300 not from 3000 before .i believe that the water intercooler is better because the inetrcooler is very very small ..0 lag .besides somebody can test in before use it .i mean about test pressure ..and water .some drag cars in greece they use it they work fine
Old Jun 9, 2011 | 10:15 AM
chaffe's Avatar
chaffe
In the uk (especially scotland) there is nothing better than an air to air intercooler when its -15 degrees!
Old Jun 9, 2011 | 10:16 AM
Joshy's Avatar
Joshy
Dreamer
any dyno plots as that sounds interesting wouldent of thought it would make a massive difference TBH..
Old Jun 9, 2011 | 11:21 AM
sierrafun's Avatar
sierrafun
rs 500 cooler is with angles .what does it means ?the air must to 90 degrees to go inside and outside the cooler.... its stops a bit the air to go to the trottle body .also is very big the air must go down to full up and then up to exit then .the watet coller is difirent its very small one way posibol the shape of the cooler .it can be full up very quickly to go to the throttle body
Old Jun 9, 2011 | 11:22 AM
sierrafun's Avatar
sierrafun
in creta i living we have 30 c today .
Old Jun 9, 2011 | 11:43 AM
stu21t's Avatar
stu21t
Do those chargecoolers look any good? They look a bit home made to me.
I need a new one and have been getting quotes around Ł750
I could get a bigger 1 from that ebay shop for under Ł250!
Would any1 on here use 1?
Old Jun 9, 2011 | 12:47 PM
chaffe's Avatar
chaffe
my mates got something similar on a 2.8 v6, works quite well (no real rise in ACT in live data)
Old Jun 9, 2011 | 05:23 PM
stu21t's Avatar
stu21t
i was thinkin of this 1.
http://cgi.ebay.com/Turbo-Water-Air-Intercooler-16-x12-25-x4-5-/110511540534?pt=Motors_Car_Truck_Parts_Accessories &hash=item19bb004936
its to go in a 400bhp cossie runnin a t34 at 2bar
Old Jun 10, 2011 | 06:09 AM
chaffe's Avatar
chaffe
that is the one he is using
Old Jun 10, 2011 | 08:27 AM
Joshy's Avatar
Joshy
Dreamer
if it was my car mate i would look for a more reputed company, such as;
AVT: http://www.chargecooler.co.uk/
there 400bhp core is Ł485..
its more expensive, but the quality is night and day.
Old Jun 10, 2011 | 09:48 AM
sierrafun's Avatar
sierrafun
pretty good i never seen something like that
Old Jun 10, 2011 | 10:50 AM
Joshy's Avatar
Joshy
Dreamer
yep.
im looking at something like this when i make my sierra xr6i
Old Jun 10, 2011 | 11:02 AM
sierrafun's Avatar
sierrafun
yep.
i see at the website that they use ice for application up 1200 hp .but i dont understad how it works .
Old Jun 10, 2011 | 11:19 AM
Joshy's Avatar
Joshy
Dreamer
they use ice to cool the water going through the chargecooler to nearer or under 0 cesius, this means that the chargecooler can cool down the intake air much more effectivly to a lower tempereture.
Old Jun 10, 2011 | 11:33 AM
sierrafun's Avatar
sierrafun
always they use new ice minutes ago before they run in drag race ?
Old Jun 10, 2011 | 11:35 AM
Joshy's Avatar
Joshy
Dreamer
yes
Old Jun 10, 2011 | 11:43 AM
sierrafun's Avatar
sierrafun
yes
i suppose not for the road unless you stop the car and going every 10 minutes full with ice the tank
Old Jun 10, 2011 | 11:55 AM
Joshy's Avatar
Joshy
Dreamer
http://www.google.co.uk/products/cat...ed=0CG0Q8wIwAQ
problem solved
Old Jun 10, 2011 | 12:07 PM
stu21t's Avatar
stu21t
Problem with the avt ones is i dont really like the fella that does them and the size isnt really any good to me.
I think im gunna end up with a garrett bar and plate core done by specR.
Old Jun 10, 2011 | 12:15 PM
sierrafun's Avatar
sierrafun
buy one charger cooler kit plus the machine for ice is a gift .heehehhehehe: grin:
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
