Rear caliper conversion on mk4 escort
So guys I want rear disks and calipers on my pride and joy xr3i
So what does any one surgest to do with it, And any one no wear the best place is to buy a conversion from? And also is it worth doing?
Keep the money in your pocket would be my best advice. The drums are more than capable of delivering the braking effort. If you fit rear discs you will have to fit a bias valve taking all the extra effort away or it will be very likely to lock the back wheels up and send you ff the road into the local scenery.
If you're the chap with the XR3i I would go with an ST170 Focus conversion up front and upgrade the rears to RS Turbo drums as they're bigger than the XR items
do they fit straigh on the brembos?like with the pad holder obviosuly?i was just going too buy willwoods i like the look of them lol
Buy the Focus ST170 calipers (they are slightly different to the Mondeo items) and 300mm discs and bolt them up, direct swap iirc from when mine were done.
Until my drums are proven to be unable to cope with the track use I shall be keeping them. The odd check and clean and they're still spot on
james kiely
28-08-2015 08:58 PM
mrice0107
21-08-2015 07:55 PM
track.focus'd
12-08-2015 05:53 PM
