what is AWS?
You mean the master cylinder
AWS (Auxillary Warning System) this applies to MK1's as they had a sensor built into it IIRC for the low level, on MK2's they do not have anything to do with the brakes on it, but it will activate the warning light (As would the MK1 in addition to the above (I think) in any case one wire is for the ABS and the other for the low level sender.
Martin
Martin
Auxillary Warning System mate. 1 plug, can't remember which one, goes to the ABS system, if the fluid is too low it sticks the warnign light on. The other one all Sierras have, Cos or otherwise, and is linked to the dash handbrake light, and lights up if the fluid level is too low
The black rectangular plug is the sender and the square one which is secured is the ABS one.
Martin
borboyous
22-08-2015 11:17 AM
2.0Si
Fitness / Weight Training Discussions
27-05-2006 08:35 AM
Jim Galbally
06-09-2004 01:58 PM
