3bar map sensor problem..help
Old May 27, 2011 | 09:01 PM
escoskmv's Avatar
escoskmv
Default 3bar map sensor problem..help
ive got a ggr stage 3 chip and it all runs fine on standard map sensor. got a new 3bar sensor, put it on as you do and when you start it up it runs slightly higher tick over for a few seconds then cuts out. put the standard map sensor back on and it runs fine againe. could it be a falty map sensor or just need setting up?? by the way its 2wd. any ideas people?
Old May 27, 2011 | 09:50 PM
axelriet's Avatar
axelriet
You can never, ever, change the type of map sensor unless the mapping is re-done too. Put back the sensor that the chip was made for!
Old May 28, 2011 | 07:50 PM
As it's a stage 3 I assume it is meant to have a 3 bar map sensor ?, if you don't know you need to find out by asking who ever wrote/supplied the chip, it MUST use the one that was present when mapped, or chip was written for.
Old May 29, 2011 | 02:59 PM
escoskmv's Avatar
escoskmv
i brought the car with ecu allready chiped. ive had a look at the chip an its got ggr stg3 on it. never had a 3bar map sns on it thow. think ill have to book it in somewere and get it remaped. can you buy of the shelf chips for spec of engine etc?? thanks for the help
tony
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
