push button start
Old May 26, 2011 | 07:28 PM
timothy315's Avatar
timothy315
Lightbulb push button start
hi there!! would anybody help me on how to distinguish the color coding of wires for the ignition on the steering column of my focus 99 zetec 1.8 petrol. because i was trying to bypass the "turning of key" (i dont like this stuff)ooops!.all am gonna do is push 1 button for activation of lights/auxiliaries and the 2nd button is for engine start/running.any suggestion to modify this? here are the wires anyway...
--GREEN CONNECTOR--
1.BLACK/YELLOW-??
2.gray/orange--starter
3.green/black--??
4.white/green--??
--BLACK CONNECTOR--
(BENEATH THE COLUMN)
1.BLACK/WHITE--??
2.BLACK/BLUE--??
3.BLACK ORANGE-??
4.GREEN/RED--??
Old May 26, 2011 | 07:50 PM
vaughant's Avatar
vaughant
Not sure of the exact wiring but one will be a perm live,one switched,one to starter and a negative cable.best to identify them using a multimeter plus you'll need a hefty switch or a wire in a relay as the starter does draw a lot of current although your starter button kit should provide this.
Beware you will still need the key in or around the area of the black ring with the thin low tension wires as this is your PATS immobiliser system and it will NOT start if it doesn't sense the passive transmitter in your key (the little red tab on your key houses this).
I've seen people tape up the key near the pats ring so the car still starts but you do lose your immobilser then as effectively anyone who finds your ignition system could just start the car.
I've never actually done it,but I've toyed with the idea of soldering wires to extend the switch to a hidden location and just use the key to unlock the steering and then the push start to fire the car up.
Old May 26, 2011 | 08:09 PM
RichieST's Avatar
RichieST
Don't forget the steering lock!
Old May 27, 2011 | 08:16 PM
slimwynn's Avatar
slimwynn
or this could happen http://www.youtube.com/watch?v=Wx-Pz...eature=related
Old May 27, 2011 | 10:42 PM
timothy315's Avatar
timothy315
thanks a lot vaughant and slymwinn! i have learned that you can disable/bypass the PATS system by the use of a certain software which is being used by hi-tech car locksmith.it's playing in my mind to put a biometric scanner(which comes from my hp junk laptop) as part of the starting system. so anybody can help disabling the PATS system?thanks
Old May 28, 2011 | 12:10 AM
vaughant's Avatar
vaughant
Anytime mate,I`m not confident that the PATS system can be disabled,I just think that software is to reprogram new keys but I`d be interested to learn otherwise as I know for a ford which has no keys and is right up my street.
I could swap the whole system over (ecu etc) but I cant be arsed!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
fuzzy
Sep 4, 2015 10:11 PM
kevin36
Sep 2, 2015 06:24 PM
