What engine?
Old May 19, 2011 | 11:41 AM
RstAaron.'s Avatar
RstAaron.
Default What engine?
I want some ideas on engine choice for a Triumph Herald...
The car will hopefuly be my track/fast road car and I'm looking for something a bit different. Powerwise I'd like around 150-170bhp. I've seen a 100e with a cvh turbo engine and I like the thought of the same in the Triumph. I don't have a massive budget but I'm in no hurry so can save for something decent.
So ideas/ thoughts please!
Old May 19, 2011 | 12:22 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
2.0ltr Zetec on throttle bodies? A good set up would be running around your preference, I've seen some running 190+ too so there's room for more. Talking of room, not sure how much space is in the bay so that could potentially be an issue.
Something different like a B series Honda engine? Or even K20 out the DC5 Integra would be awesome.
Ben.
Old May 19, 2011 | 12:24 PM
zippyobrien's Avatar
zippyobrien
Vauxhal red top and omega box
Old May 19, 2011 | 12:30 PM
RstAaron.'s Avatar
RstAaron.
Ben.
Plenty of room really, people have stuck v8's in them before! I like the idea of a honda engine but running them rwd could be difficult? Zetec is too obvious
Old May 19, 2011 | 12:32 PM
joffy's Avatar
joffy
SLOW LEARNER
S2000 engine and box, on throttle bodies and a decent ecu, would sound absolutely mental
Old May 19, 2011 | 12:36 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
That's a good idea, F20 I think it is out S2000, although I can't imagine they're as commonplace as the B series.
If you want something different, what about a BDT-E? Or N/A Cossie!
Old May 19, 2011 | 12:37 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If he wanted 250bhp I would agree on the S2000 engine, but way too much money when you dont want big power anyway.
Vauxhall XE IMHO
Old May 19, 2011 | 12:46 PM
RstAaron.'s Avatar
RstAaron.
S2000 would be awesome but as Chip said it would be overkill for what I want. Xe would be good... BDT-E or NA cossie would be the tits lol.
joffy's Avatar
joffy
SLOW LEARNER
Missed the 150-170 bit and got carried away, would have to agree with chip then, C20XE for me
Old May 19, 2011 | 12:53 PM
RstAaron.'s Avatar
RstAaron.
Ha ha! It's easy to get carried away when thinking of obscure engine swaps. Don't want mad power otherwise everything on the car will have to completely change and then I may aswell have started with a faster more capable car.
Chip's Avatar
Chip
The Omega V6 engine and box is another cheap option if the bay is as big as you say, and they dont weight a great deal more than the XE, 20kg or something IIRC
Old May 19, 2011 | 01:03 PM
caprizetec170's Avatar
caprizetec170
MX5 engine and box small light and cheap
Old May 19, 2011 | 01:04 PM
caprizetec170
MX5 cheap small and light
Old May 19, 2011 | 01:09 PM
Chip's Avatar
Chip
How easy is the management on those to put into another car?
Ive never tried.
I know the C20XE and Early V6 vauxhall engines for example can be wired in easily in a few mins, but the later vauxhall engines cant, is it the same with the mx5 that there is a cutoff point at which they start to become harder to intergate into a different car?
Old May 19, 2011 | 01:11 PM
RstAaron.'s Avatar
RstAaron.
Like both of those ideas... V6 wins on noise but mx5 makes a lot of sense.
Old May 19, 2011 | 01:13 PM
caprizetec170
Ive never tried.
NOt sure on newer ones pre 98 ones simple enough to split looms and wire up only couple lives fuel pump and earths as far as can remember
Old May 19, 2011 | 01:15 PM
Chip's Avatar
Chip
MX5 sounds like a good option then if its that easy to go in, they certainly drive nicely etc
Only slight issue might be getting the power though, they are quite a way short of 170 standard IIRC (if someone says 150-170 they mean 170 or more normally really, lol)
Old May 19, 2011 | 01:23 PM
RstAaron.'s Avatar
RstAaron.
160 bhp will do me! Around 200bhp/ton is my aim.
Old May 20, 2011 | 09:42 PM
What about a BMC B series(1.8) on 45's ?, will be more classic as well that way, just an idea, be a shame to spoil a classic with other choices mentioned imo.
Old May 20, 2011 | 09:50 PM
martysmartie's Avatar
martysmartie
What about a Vitesse engine, surely this is fairly straightforward to fit seen as it was fitted to the same car? Obviously it dosen't have the power you want natively.
Martin
Old May 20, 2011 | 09:53 PM
RstAaron.'s Avatar
RstAaron.
If I did that I could just pinch the engine from my MGB GT lol. I'd love to put in a tweaked Dolly Sprint engine in it. The car is nothing special really so not too worried about mixing it up a bit
Old May 20, 2011 | 09:55 PM
focusv8's Avatar
focusv8
Not through the standard independant rear end??
RstAaron.'s Avatar
RstAaron.
Martin
A vitesse engine is available to me, may look into what can be done power-wise...
Old May 20, 2011 | 09:56 PM
caprizetec170
you'd spend a fortune trying to tune one of these and they'll never make great power due to 5 port head weigh a ton and dont like to rev and sound shit.
RstAaron.'s Avatar
RstAaron.
Not standard rear no! I want to live! Lol
Old May 20, 2011 | 10:02 PM
Chaz888's Avatar
Chaz888
The B engine sounds good had a 1.8 done the head with std cam an carbs you get about 90 bhp with boreing to 1.9 -1950 good cam an 45s or big SUs should be about the 150 mark maybe more. ho and sorry cannot agree to the revs I had cooper 998 A type tuned B type and rover v8 all rev very well just need to build them right.
Old May 20, 2011 | 10:11 PM
RstAaron.'s Avatar
RstAaron.
Originally Posted by Chaz888
The B engine sounds good had a 1.8 done the head with std cam an carbs you get about 90 bhp with boreing to 1.9 -1950 good cam an 45s or big SUs sould be about the 150 mark maybe more.
That may be a plan for my MG when I refresh it later on...
Old May 20, 2011 | 10:15 PM
Chaz888's Avatar
Chaz888
Do it ! it will shock you how much an engine can change its character an power! what years your B ?
Old May 20, 2011 | 10:17 PM
J1mbo's Avatar
J1mbo
B1mbo
Hang on did I just rear bdt-e? As in 25 grands worth of bdt-e
K20 Honda engine are big bucks too
You could get a b18 series engine out of a dc2 reasonable 192bhp
But fitting It would be fun, something that fits direct to the gearbox would be nice
RstAaron.'s Avatar
RstAaron.
1971 mate My daily driver currently
Old May 20, 2011 | 10:20 PM
caprizetec170
to build em right starts to cost serious bucks trust me ive worked on mini's minors, migets and had few mgb's much cheaper and more reliable go for newer lighter engine.
another option maybe toyota 4age or 20v black top
Mark V8's Avatar
Mark V8
There was a Triumph Vitesse featured in PPC magazine fitted with a Triumph Stag 3 litre V8, keeping it all in the family.
Old May 20, 2011 | 10:21 PM
RstAaron.'s Avatar
RstAaron.
One can dream...
Old May 20, 2011 | 10:24 PM
RstAaron.'s Avatar
RstAaron.
Saw the Vitesse in PPC, as much as I'd love a v8 not really the style of engine I'm after, a revvy 4 pot makes most sense so the 4age could work and hs been done in Anglias/ Cortinas etc.
Old May 20, 2011 | 10:35 PM
caprizetec170
NIce looking mgb there much better then my old rolly polly rubber bumper piece of crap.
dont forget other thing with likes of 4age engines theyre much lighter and lower than old engines so car should handle better 2
Old May 20, 2011 | 10:43 PM
RstAaron.'s Avatar
RstAaron.
Cheers! Looks better than it is as it's just been washed lol. Paint is shocking but the car is solid as a rock and most importantly tax exempt!!
That's what I want really, lightweight and revvy. Can always build my MG with something a little lazier as that would suit the GT style.
Got a problem with too many projects though, also have a 23k 1 owner Mk1 Metro and a Rover 420GSi estate with a 220 turbo engine in... It wasn't intentional to end up with all these BL/Rover related vehicles...
Old May 20, 2011 | 10:46 PM
Chaz888's Avatar
Chaz888
nice B ran an 67 MG-B-GT with a v8 for six years in all weather they can make a very good daily drive after all they were modern cars once !
Old May 20, 2011 | 10:50 PM
caprizetec170
You must really love hardship with all them
Old May 20, 2011 | 10:56 PM
RstAaron.'s Avatar
RstAaron.
Haha! The only one to give me trouble has been the Rover, give you one guess what's wrong with it, but the troubles stem from the average quality of the engine conversion. It's currently being sorted and will be back and surprising a few VXRs and STs again soon
The Metro and MGB always start first time in all weathers and not started using the Triumph
Old May 21, 2011 | 12:29 AM
RstAaron.'s Avatar
RstAaron.
Had a think... what about an f7p/ f7r engine from a Clio/ Megane? Attached to a Volvo gearbox as seen in many 340s? I know they have rear mounted gearboxes but must be possible to fit somehow?
