Mk3 Ford Mondeo Rear Subframe Bushes
I need to replace the rear subframe bushes on my Mondeo and just found this kit on ebay, is this kit any good? worth it? http://cgi.ebay.co.uk/FORD-MONDEO-REAR-SUBFRAME-BUSH-REMOVAL-TOOL-4-BUSHES-/280197595677
Brian
Brian
I used these in mine, easy to change too as you just remove the old rubber bush and leave the metal outer sleeve in the subframe, clean it out with a wire brush attatchment on a drill and pop these ones in http://cgi.ebay.co.uk/Ford-Mondeo-MK...item4cf7009fa1
I don't know if the tool + the bushes would be cheaper, but I know if you were to take it into Ford's, they'd swap it for a new subframe rather than mess about swapping bushes.
and they would probably charge an arm and a leg for it too!!!! just 1 rear lower spring arm on a mk1 focus is Ł125 from them so i hate to think what a whole fucking beam is.
get some polly ones, far easier to change as you just get a blow torch (domestic is fine) to burn the old rubber out and clean and grease the oe sleaves. you won;t have any bush allignment issues then either.
track.focus'd
12-08-2015 05:53 PM
