M.O.T Failure, Emissions HELP!
My Mk2 2001,1.8 mondeo has jst failed its m.o.t on high emission levels, Any ideas anyone? Cheers
was the cat nice and warm before it was tested, not just ticked over for a few mins at the garage ?
My old Mondeo used to stuggle a bit with emissions until I started giving the car a good old thrashing on the way to the MOT station. Still do it today, a couple of runs up and down the local bypass before pulling in.
HTH
HTH
No the car had not bin run propaply for about a week before the m.o.t, and i have never taned the car since av had it, It passed on evreything else! Not even a advisory! Sods law! Bin told it could be a number of things!
Not my day at all!
Not my day at all!
The MOT test has to ensure the car is up to working temperature before taking the emmsions test.
As the CO is that high, I would guess that there is an engine managment issue.
Is the engine warning light on and have you had a code read done ?
Thers no light on, I have got it booked in for diognostics first thing tomoz, any ideas what could be causing it? Am hoping its a recent proplem because if never noticed it smoking meself.
I would say more likely to be Lamda sensor gone , even if Cat has gone you would not expect the reading on the MOT emmisions to be showing a 0.806 as the onboard one would always try and get it as near to 1 as possible , it is more likely not reading correctly ( on the weak side ) so it is richening mixture up and hence the high CO and HC readings , just my thoughts
Exactly what i was thinking!!
I think the same as jonathanj, although the mot test has to ensure the engine is up to temp, some cats, esp aftermarket cats can cool so quickly they stop working effectively enough after idling for a few mins, on cars that are already a bit coked up, bloody good thrash on way to mot test is best bet ime.
My astra always without fail, fails on the idle emissions but always without fail passes on fast idle, that's fairly std for astras so I'm told on mk3's.
regardless of engine temp during the emmision test the lambda reading will is within limits as they are heated sensors, usually low lambda reading 80% of the time is just a tossed lambda sensor and causes over fueling, and in turn high hc's but diag will show this. may not come up with a trouble code but it switching can be checked easily. even a faulty ect sensor would cause this too and maf
Turbocharging Technician
HTH
HTH
What was the idle emmisions? If it passed at idle then its not the cat is it
Had it at the garage ysterday for scanning and both lamba sensors and cat seem 2 be in order?, put sum stp in fuel an give it a pasting up the motorway and it seems 2 have cleared it out but seem 2 still have a slight bit of smoke?? The car runs like an absolute dream tho.
maybe you have a valve stem seal issue or piston ring problem, or even an egr fault. The simple fact is no one on here can properly diagnose your problem without seeing the car
