Poly bushes
Poly bushes
hi, i have a full set of poly bushes to fit on my 4x4 sapphire cosworth and was wondering how much and time it would be to have them fitted???
John.
John.
sorry mate im going to fit them in the summer but what im doing is setting aside a whole day to do it as i got to fit coilovers also!!! and i would say fit your bushes where the car is ok to be left because if a bolt snaps or worse you can leave the car where it is safe for the next day and you aint gonna worry about it.
Originally Posted by SPADGE
Do not polly bush the rear beam!
It will make the car handle shite!!
Quite many people don't agree with you :-/ strange :-/ Can you say more?
The theory is this.
In the rear beam, the two "bushes" each side to the trailing arms are not bushes at all but spherical bearings.
By Polybushing, you are altering the way in which any vibration/movement is taken up in the arms.
I can see the theory but personally I'm not convinced. I did it to my cossie, and it handled superbly well.
this topic will never be solved as everyone has got there own opinion on it........the best people to listen to is the people who have done it!!!!!!
Technically, the car is propelled forwards by these two spherical joints as the driven rear wheel is bolted to the swinging arms, so they have a hard life in a modded cossie, especially one subjected to burnouts and other childish crap.. roflol
This is why Ford themselves deemed rubber as not up to the job and redesigned teh cosworth system to suit its 204bhp (Remember the whole sierra range was fitted with rubber bar the Cosworth's)
The spherical joint is a form of what you may well know as a "Rose Joint" and has no flex in it whatsoever, so a rubber bush will never be as good as it period. However, wether us road drivers will be able to tell the difference is certainly open to debate.
I fitted them to the 500hp 3 door i built the year before last with totally new suspension. Harvey at SCS told me not to and i ignored him! After the car was finished it always handled like shit and felt like it was trying to steer from the rear exactly how Harvey warned me it would!! Every other cossie i have owned since then has had standard bushes fitted and felt much better until now! The Gartrac has them and guess what 4 wheel steer all over again
Spadge I don't understand anything - on standard beam bushes (I have new Escos ones from Ford) you can feel quite well rear steering effect at high speed corners. I already bought Powerflex ones from Cossymad and I will tell what is the effect for sure when I fit them.
Originally Posted by Stu @ M Developments
Azrael,
Originally Posted by Vic
can we have a picture?? paints a thousand words.. apparently!
No.4 is REAR BEAM BUSHES - two big round things
No.5 and 6 are REAR TRAILING ARM BUSHES - pair of cylindrical things you put into the arm.
No.4 when is a Ford rubber element makes the car four wheel steer. Can be felt at hisgh speed corners when half a second after corner initiation you feel something similar to rear end slipping abut it's only movement in rear suspension.
I have No. 5 and 6 change to Powerflex, and no problems. No 4. is on it's way in.
Its an English thing...
Whenever anyone shouts "Dont poly the rear beam" they mean the swinging arms
You learn english for 15 years and you still can be surprised
Sorry my fault for not being more specific
DO NOT POLLY BUSH THE REAR ARMS ATTACHED TO THE REAR BEAM AS THIS WILL MAKE THE CAR STEER FROM THE REAR
Right now we know. Still I did and it is much better that it used to be
Then your old ones must have been so fooked that anything would feel like an improvement
Lol be honest you just like them and think they are better because they are yellow or purple or whatever gay colour......
Stu has explained already in a better way than i could so i won't go into it again!
Maybe on a 4x4 it just isn't as noticeable as on a 2wd car?
I was just joking when i mentioned you liking them because of the pretty colours but i feel i may have hit a nerve
Azrael,
I can't see in what Stu has written anything about why poliuretane bushes wouldn't work :-/ Can you? Original ones are just ruber + two steel pices one on the inside one on the outside they aren't any uniball (spherical) joints fromwhat I have seen :-(
I did say they are a Sperical joint.
This is not a rubber joint at all, maybe yours was not a genuine rear set?
I assure you your poly bushes are a tad less shore hardness than a spherical joint
Maybe someone will post a pic, Brom perhaps, im sure hes knocked a few out in the past
If you look a little closer, you will also see that the arm is bent to fook too!
Don't know about the bushes being normal sierra ones, but all I know is that I absolutely destroyed them getting them out - fookin hammers, sockets, etc
May be cause i havent seen any for ages as i refuse to fit the bugers, but they look like std sierra bushes in that piccy
DavidK
27-09-2015 02:55 PM
