map sensor question
Old May 2, 2011 | 09:37 PM
escoskmv's Avatar
escoskmv
Default map sensor question
wot p.s.i can you run on standerd map sensor?
Old May 2, 2011 | 09:47 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
standard on what?
Old May 2, 2011 | 09:51 PM
scoobydooby914's Avatar
scoobydooby914
Standard map sensor is 2 bar so I'll wait for someone to correct me but I think it will only read up to 1 bar.
Old May 2, 2011 | 09:54 PM
whizzisat114's Avatar
whizzisat114
I head it was half posative and half negative so you should get 1 bar pos and 1 bar neg off a 2bar map sensor
But ive also heard people say that they get 28psi pos out of a 3 bar map sensor so id like some one to answer this question aswell
David
Old May 2, 2011 | 09:56 PM
scoobydooby914
Doesn't a 3 bar map sensor read up to 2 bar?
Old May 2, 2011 | 10:01 PM
whizzisat114
should be 1.5 pos and 1.5 neg i think 1 bar = 14.6psi if my memory serves me well so that should be a max of about 22-23 psi should'nt it ?
Old May 2, 2011 | 10:14 PM
escoskmv's Avatar
escoskmv
Originally Posted by clarke5700
standard on what?
2wd saff cosworth
Old May 3, 2011 | 12:05 PM
James @ M Developments.'s Avatar
you can run as much boost as you want on either map sensor as long as the mapping is correct,
just because the map sensor reaches its max, doesnt mean you cannot fuel it there for 60 psi if you wanted,
but it would be rich from the map sensors max reading all the way to the peak boost it was mapped for, but correct at its peak. if the mapping was correct.
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
