pirelli p-zero compared to r888s ?
you will get more grip with 888s than which pzeros thats a given.
will it be enough for you to stock wheelspining, no.
will it be enough for you to gain more traction in higher gears than before, yes
what rear wheels are you running 19x11 or 19x12?
Well Dave Jackson in his escos could only run low boost in the first Time Attack race as it was just lighting up the rears with id guess 600hp... Iv heard that the new dunlop SP2's? are meant to be pretty good or some new yokies also, but what they are im not sure mate?
sweet cheers jay, the annoying thing is i have 1 brand new 305/30/19 pirelli here that came with the car but there Ł300 each and i aint spending Ł300 on a turd, id rather spend Ł600 on gold and sell what i have here tbh.
http://cgi.ebay.co.uk/295-30-19-YOKOHAMA-AD08-TRACKDAY-ROAD-TYRES-2953019-/170475977061?pt=UK_Cars_Tyres_RL&hash=item27b128f9 65
what about those, only ones i could find ad08s ?
or 888s are actually cheaper
http://cgi.ebay.co.uk/295-30ZR19-Toy...item3f081c6ab2
i want to drop from 305 to 295 so i gain 5mm clearance then i can hopefully remove the wheel spacer so gain 10mm outside clearance overall then soften rear suspension for more squat ready for pod launch.
they dont do ao48s in 19s ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
i can get r888s though for Ł270
the question is though how much grip will i gain over the pirellis ? im thinking about trying some 150 lb springs in the back to get it proper squating.
i dont wana spend Ł600 on tyres and still have no grip below 100 mph
lol
i dont fancy buying new wheels though the 19s on it are mint.
but that being said 295 or 305 on the back should still grip fairly good.
You need to consider usage.
Ive had various rear tyres, and TBH normal road tyres are fairly useless on normal roads when putting the foot down.
But for road driving they are totally fine at legal speeds with the added benefit of being usable in the wet. ( again driving very normally )
By comparison....well, I can still easily smoke 888's or V70's around 100mph or so. So are they any better ? Are they worth it ?
Very difficult to answer. The 888's do grip better and they last surprisingly well ( I got about 3k for rears before illegal ).
V70's due to crappy tread depth design, were barely only 1500 miles before they were illegal and they dont grip as well as the 888's
Would I buy either again for road use ? No. Simply not worth the extra money when even at silly speeds there is still no grip.
But for limited summer use, I am going to consider the Federal FZ201 or whatever it is. Simply because it looks good, is available in my size and seems damn good value compared to 888's etc !!
255/40x17 rear priced at around Ł125 ea.
But no way will I pay Ł2-300 for a single tyre that I know wont grip anyway.
I also considered the Hankook RS2 or whatever it is. But that Federal just looks good.
Havent bought them yet though, as car is in lots of pieces lol
Last road tyres I had were Hankook Evo12's at the back. They arent bad. Marangoni also make some decent tyres that arent silly money.
I have a pair on the front and did try them briefly at the rear and was surprised how good they were for normal cheap tyres. Actually better than the Hankooks I have on the back and that's a smaller tyre too.
what tyres do you run at pod ?
Happily retired
I have 2nd gear grip with 888's only better ive used is Dunlop DO1J which are now obsolete. Tyres are not the problem in this case. You need to control the squat not just increase it. I got BAD to advise on mine & they fitted dual springs to control the squat. Think it can squat 30mm or so before its controlled its not my area so let the experts work it out. Works though, press the pedal & it piss's off up the road ( in the dry with tyres warmed up).
As regards Race Logic i got them to set mine up before Totb & the 5 fastest drags were done with it switched 'off' it really is just masking a bigger problem & not very well either.
that very much does suprise me mate, i assumed you were running recent widths all around.
one it being a big power supra it is sort of a given you have wide wheels, but then running a wide body id have thought the previous owner would have done it just so he can get some wider rubber on the back.
as i mentioned to you before, im got wide arches on mine now just so i can run 285s on front and 335s on the rear)my 888s are Ł350 each!!!
plus im about 600kg lighter than you and have less than half the power so god knows how you get on.
i always wonder how people cope with 500bhp cossies on 205/40/17s when i could spin 255s up with 350bhp.
would you think in the future of getting this done:
putting your rear wheels on the front, then having your front wheels spilt(they look like split rims) and having 4inch added into them and stick them on the rear.
Its quite a popular thing to have done and if done properly will be just as strong as before.
also if they arnt split rims it will make no difference as they can be done anyway.
if you want some detailed pics i can show you to give you ideas?
if i want 335 r888s id need to run 18" rims.
rltc is ok in lower gears but 3rd gear doesnt feel good when it cuts in.
the squat should of helped abit but it seemed to do absolutely nothing, although the tyres have loads of tread on them they are probably 2 years old now as its been stood and they are only a road preformance tyre not a racing derived semi slick like the 888s so surely have to help up in the gears.
do you kinow what rear spring rates you run ? im tempted to put in 150lb springs like i put on my saph thats used to drop its arse and grip and explode the diff
ah that sucks, and your looking at Ł1000 for a new set of 18s in 18x10f/18x12r then another 1000 for tyres for it, 2k is alot of money to throw around for traction.
still those 888s should help improve things, you also need to look at camber changes as the car squats as thats important.
theres no point in the car having 60mm of squart if your tyres add 3 degrees of camber as then you have less footprint.
have you done any research on that yet as if maybe you might need to pull some camber out of the static(not moving) setup
it does squat and drives really nice not bouncing around on solid suspension like the gtr did.
i have no illusions grip in 1st is never going to happen on any road tyre, 2nd maybe and 3rd is a must.
if needs be i will add adjustable suspension gotta look into it if needs be.
this is just road/track setup so handling and grip, i want some 17" with massive drag tyres on for pod if im gonna try do it properly.
Ive used various tyres at Santa Pod.
Fastest was MT ET STreets wrinkle walls. MT DR's not far behind. Although could maybe have pushed them harder.
Also use Nitto 555R which worked well and netted me my first 10s run ( 10.5 ) a few years ago.
Also used 888's at Santa Pod and they were like driving on ice. No grip at all.
I have some Hoosier DR's here too that Ive used locally on an airflield along with the MT's
Of all the tyres Ive tried the Hoosiers do grip the best, although Ive never used them at Santa Pod.
But different tyres just work differently on various surfaces and road/track conditions.
Ive had those same Hoosiers and 888's break loose at 190mph on a less than ideal track, which tends to scare the shit clean out of you.
17" is no problem. Most of the major brands offer 275/40x17 in their drag radials.
Whilst none of them are road legal, the Nitto 555R would be a good compromise if you wanted to use them on the road. As at least they have a sensible looking tread pattern.
Nitto also do a 315/35x17 in the 555R
what rwhp is your granada mate 1000 ?
Only place for Nitto's is the US.
Although places like Hauser, Andy Robinson Race Cars etc would be able to source them.
Due to postage, there really isnt any huge saving involved buying direct from the US.
But is it road legal, or to use on the road to/from a venue or purely for racing and never on the road ?
Whilst the Nitto's are not road legal, you'd probably get away with them on the road as they are a reasonably normal looking tyre. The only thing they lack is the E-marking
DOT marked means nothing here although it satisfies most drag strips for street legal, just as it is in the US.
If it's outright grip, I think I'd say go for the Hoosier drag radial and then the Mickey T. Hoosier just looks like a slick though. Last 2 pairs I just bought direct from Hoosier in the UK. Fuck they aint cheap !!
As for power, I dont really know, but it's sure as hell nowhere near as high as 1000rwhp
stevie what about these ?
http://www.summitracing.com/parts/MTT-3723R/
305/35/19 mt radials, its says dot so i assume they would be legal and ok for pod ?
your chevy v8 twin turbo aint ya stevie ? the missus just asked we just watched your pod video
