engine management light
Old May 1, 2011 | 05:46 PM
cowane's Avatar
cowane
Default engine management light
I have a 2lt mondeo tdci the managent light is on, how do I gain access to these codes without going to a garage.
Old May 1, 2011 | 06:52 PM
B19 JUB's Avatar
B19 JUB
you need to get the codes read that are stored in the ecu.any small garage with a scanner should be able to do that for u reasonably cheaply
Old May 1, 2011 | 07:35 PM
Chaz888's Avatar
Chaz888
Get a scanner they can be cheap and very handy!
Old May 2, 2011 | 06:00 AM
vaughant's Avatar
vaughant
only scanner on those,obd 2 will be fine.I paid £75 for my mac tools one and wouldn`t be without it.
Old May 2, 2011 | 08:15 AM
scoobydooby914's Avatar
scoobydooby914
I bet you it's either an egr fault or an injector fault. Where are you located??
Old May 2, 2011 | 05:52 PM
cowane's Avatar
cowane
I am in Rutherglen near Glasgow.
Old May 2, 2011 | 05:57 PM
J1mbo's Avatar
J1mbo
B1mbo
Scooby Dooby Is right, they're prone to injector faults and egr, normally you can just take the egr valve off which is very easy and clean it but of that don't fix it then its a valve which arent overly cheap
Old May 2, 2011 | 06:19 PM
GVK.'s Avatar
GVK.
Cheap code reader here :
http://www.gendan.co.uk/product_GDEOBD.html
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
