General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
in that case its how far you push your injectors, as at 6500rpm at say 26psi you might be running lean as you are running out of injectors so 24psi is safer for example
but i dont no what focus rs injectors are rated for
put up the spec of your engine..
it made 300bhp with that much boost id think it would make more then that .. mines doing it at just 17psi dude .. i suppose it i uised a t34 i would need more boost then because the turbo smaller?
2.0 zetec running a t34.63 housing 3 inch mogoose exhaust
omex 600, focus rs injectors
rover gti inlet manifold, golf gti throttle body
airtech single pass intercooler
mines omex 600,rover inlet,pro alloy intercooler,750cc injectors .. by the way if you need same injectors i have some . so if i had a t34 id need same boost as you ? mines standard internals though.. what about yours?
Yes that's correct mo, we have done a few 290/300 bhp on std rods with c20 pistons on t34 don't think they will take much more power on std rods though
got wossner pistons, pec rods, arp rod bolts, piper valve springs with a recon head
i run 17psi my engine is standard apart from double valve springs ... its 300-330bhp standard rods and skimmed pistons ..been running this for ages and its been very reliable tbh. so if i sell the t4 and put a t34 on it [less laggy] . how much boost should it run to make up the 300bhp? and i might drop it to reyland for a remap with the t34 on it so how will they know that my engine is maxing out ? dont want any tuner blowing it up like taking it too far .p
T4 17psi from a 2L and and only 300bhp, are you sure from a T4, I make that on the cos at 17 psi with a T3-34, T3 comp housing machined out to take t34 trim.
