MK2 Golf with a 1.8T 20v Conversion
#41
At the end of the day there is no replacement for displacement, and the vr6 doesnt weigh much more than 1.8t in actual fact, its a myth that it makes the car front heavy, you just need slightly different compression rates on the suspension to compensate (which no one does, then complains).
stock block, 8:1 cr, gt35r (1.06), SP 263, SP SRI, 3" turboback, 95 octane. 20psi
Goodluck doing that on a standard 1.8t, we know the conrods fail at 300hp for starters!
#42
And a good budget setup:
ARP head Studs
8.5 - 1 C2 Head Spacer
c2 42lb injectors
t3t04 garrett 60 trim w/63 ar exhaust
medium size front mount intercooler w/ 2.5"in 2.5"out piping
2.5" DP
C2 SRI manifold
3" cat-less exhaust
255 walbro fuel pump
407whp/368wtq @19.5
c2 42lb injectors
2.5" DP
C2 SRI manifold
3" cat-less exhaust
407whp/368wtq @19.5
#44
my mate has a skoda octavia 1.8t 4wd thats been remapped with new exhaust and induction, running about 230hp and its the nuts
i reckon one of these engines would be great fun in a mk1 or mk2 fiesta aswell good alternative to a zetec turbo maybe?
#49
Great engines with huge tuning potentials especially a mapped later bam lump. Well suited to a light and nimble track car....great spool up etc. Golfs/leons/s3s arnt the lightest of cars, stick it in a sub 1000kg car, would make a weapon!!
Last edited by H7 CYA; 25-05-2011 at 09:38 PM. Reason: Dingbat spelling.....douchebag!
#51
Slightly off topic, I'm having a 1.8T VAG lump stuck into a Mini, complete with an IHI VF34 turbo.
Spent some time looking at the engine choice and was steered to the 1.8 lump instead of the v6 one.
#52
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
