Fuel pump problems??
Old Apr 23, 2011 | 04:19 PM
redxr2i's Avatar
redxr2i
Default Fuel pump problems??
Hi my 1990 Xr2i has intermitent fault. Starts runs fine then will cut out and not start, the engine is turning over but no go. should the fuel pump make a sound each time the ignition is switched on? turned the ignition on/off a few times and i cannot hear the pump going??
Old Apr 23, 2011 | 04:36 PM
I would assume at this age yours is EFI and not MFI ?
That being the case I would expect it to prime on each key on to position 2(run), but would in any event put the pump on in the start position.
I'm sure the pump is external on these ?, if so simply put a live onto it direct from the battery, if it now starts then you know it's a ecu/wiring/relay fault.
Have you checked for a spark though when it doesn't start just to rule this out ?
Old Apr 23, 2011 | 05:16 PM
redxr2i's Avatar
redxr2i
hi sorry for slow reply yeah its an EFI and its gotta a good spark there is def no sound comin from the pump when ignition in pos 2 which is strange cos normally the pump is quite noisey for a few seconds. the pump is intergrated with the sender and i believe its a tank off job. not good! what do you know of the ISCV getting mucked up is this a possibility??
Cheers Mike
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
