Any OMEX Gurus
Old 23-04-2011 | 10:04 AM
Tank Mike's Avatar
Tank Mike
Default Any OMEX Gurus
I need to change a calabration file from LOAD VS RPM to TPS VS RPM
Any ideas?
Old 23-04-2011 | 12:02 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Mike,
Save a copy of the original map for safety, save another copy of it and put TPS against the filename and then try this
Go to SETUP
Drop down to SENSORS
Go to MAP SENSOR
Then untick the "MAP For Load" box in the bottom.
That should then default the load referencing into Alpha N for you mate
Old 23-04-2011 | 12:08 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Just bear in mind that it absolutely will NOT be any good anymore as a map of course, the values will now be nonsense.
But I assume this is just to create a basemap for you to start from in the first place Mike? Ie you are going to map it from scratch?
For that Fiesta on bodies I assume?
If so I'll give you a hand in the week if you want someone to drive it for you while you map it who knows what they are doing with holding load sites etc
*EDIT* - Forgot that you have Jack working for you full time now anyway, so you probably dont need help from me, but if you fancy doing it in the evening or something when Jack's not about the offer still stands
Old 23-04-2011 | 12:13 PM
Big Will_'s Avatar
Big Will_
What size is the engine Mike - if it's a 2.0 Zetec on bodies then I should have a pretty good cal file on my mapping laptop - will be Tuesday next week before I can get to it though...
Let me know if its any use
Old 23-04-2011 | 12:30 PM
Chip's Avatar
Chip
Its a zetec S fiesta lump if its the one I am thinking of Will, although this might be a different customer I guess.
Old 23-04-2011 | 01:28 PM
Tank Mike's Avatar
Tank Mike
Hi will thanks for that. I'll give it a try in a sec.
It's a 1.6 Zetec S engine.
Chip! Defantly mate. Jacks not on the insurance yet! It's only me and it would be handy to have someone elce drive it while I tinker.
Hoping to start it for the first time in a couple of hours. Just doing the last couple of boring bits.
Old 24-04-2011 | 05:51 PM
Chip's Avatar
Chip
Cool. I'm free wed evening
Old 24-04-2011 | 07:27 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
chip does omex 600 series run coil on plug matey ???
Old 24-04-2011 | 07:34 PM
SiST's Avatar
SiST
No you will need 710 for coil on plug.
Old 24-04-2011 | 08:00 PM
Chip's Avatar
Chip
You could get away with it if you ran wasted spark coil on plug I guess but ive never done so personally
dombanks
21-09-2015 09:38 PM
jay030787
18-09-2015 08:34 PM
Tank Mike
14-09-2015 04:56 PM
RSmark84
13-09-2015 02:29 PM
ekjim
17-08-2015 09:57 PM
