T Logic Exhausts
T Logic Exhausts
Does anyone have a contact number for them that works ?
I googled it and it came back with a mobile number which doesn't connect.
I need to get a custom repackable silencer made if anyone knows of someone else that can maybe help.
Here is the silencer, well I wouldn't call it that as it doesn't appear to silence much
The silencer is 3" Bore and 680mm in length and 190mm wide but is taller at the back than the front so it fits in the sill.
Its a tidy design, looks like its had a few repairs over time but then its never been rebaffled in 15 years so I imagine the engine has destroyed any internals it may of once had.
Not sure its ideal for your application, the only reason its been fitted there is there is literally 2 inches of ground clearance so no room to run a complete system down the length of the car unless you chop a tunnel into it which ofcourse would be the drivers footwell so far from ideal.
