Est. Throttle bodie power
Currently I got a mk3 fiesta Si with a 2 litre.
What power would I achieve with throttle bodies, cams and cylinder head porting, possible uprated con roads and pistons.
Many thanks Sean
Many thanks Sean
On 45 TB's, an unported head, a 4-2-1 manifold, 262 cams ( properly timed ) and a bottom end rebuilt to standard, except ARP bolts and heavy duty bearings, a 2.5 inch tubed exhaust with a straight thru centre box, my 2ltr silvertop shows 196 brake. If you add steel rods, forged pistons knifed crank, a well flowed head, bigger valves, much wilder cams on solid lifters I have seen 250 - 275 quoted. But an engine like that would probably cost in the region of £10k
