What volts should an alternator charge a battery at??
Chasing Radders
I just want to eliminate my alternator from playing up as its charging my car at 13.6v........
PassionFORD Member
Front quick clear screen on in the focus and rear screen on in the winter from cold shows about 13ish on the volt gauge I got in the car with an under driven alternator. Usually charges around 14-14.5V at 2000rpm or so.
I get about the same, with no load and with a heavy load I get 13V, I posted a similar thread as some get different reading, so long as it's charge is greater than the open circuit of the battery I.E 13V+ your ok.
Focus is different as that has "Smart Charge" these charge higher, sometimes around 15V+, when I tested mine with heated screen etc it maintained 14.2V.
Martin
Martin
Happily retired
A modern automobile has a 12 volt electrical system. A fully charged battery will read about 12.5 volts when the engine is not running. When the engine is running, the charging system takes over so that the voltmeter will read 14 to 14.5 volts and should stay there unless there is a heavy load on the electrical system such as wipers, lights, heater and rear defogger all operating together while the engine is idling at which time the voltage may drop. If the voltage drops below 12.5, it means that the battery is providing some of the current. You may notice that your dash lights dim at this point. If this happens for an extended period, the battery will run down and may not have enough of a charge to start the car after shutting it off. This should never happen with a healthy charging system because as soon as you step on the gas, the charging system will recharge the battery. If the voltage is constantly below 14 volts, you should have the system checked. If the voltage ever goes above 15 volts, there is a problem with the voltage regulator. Have the system checked as soon as possible as this "overcharging" condition can cause damage to your electrical system
We then have FULL calcium,(most calcium are mixed lead/calcium) which can charge at up to 16 volts and is normal for them, a calcium battery can operate perfectly in place of a std lead/acid battery, but a lead acid in place of a std calcium can go bang.
07-10-2015 12:56 PM
