power steering help please
Right i took all my alloy bits off to be powder coated,got it done re fitted it all etc now power steering not working ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
All i done to steering was took tank off got it coated put it back on new fluid etc now its a no go with it?
Anybody got any ideas please![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Oh focus rs by the way
Fill the bottle up and with the engine turned off go lock to lock a dozen times then start the car and it should work as they are prone to air locks when tank is removed. If it dont work the first time keep trying and it will clear the lock in it.
Resident Wrestling Legend
you've got an air lock in the pump
fill the tank with fluid, cover the sides to stop it from splashing everywhere, spin the wheel full lock to full lock and hold it at the lock for a second or 2 each time
eventually the air will come out and the fluid will go down
unless you've had the inside of the tank contaminated and that crud has got into the system, then you might be fucked
Rite tried again tonight,filled tank and done lock to lock then as said above fluid went down so topped it up etc and guess what? Still no fookin power steering lol
the pump must be working as you can see the fluid coming back in the tank,so wondering if the rack is fooked?
Leave it in the lock position and briefly turn the wheel so it physically won't move any more and hold it there for 2 seconds, release and look at the tank with the lid off and there should be air bubbles come up in to the tank.
Do it with the engine running and you should see the air bubbles come up, repeat going from lock to lock.
Mine took quite a while to bleed but it came through eventually.
07-10-2015 12:56 PM
