Escort van injection timing
Old Mar 22, 2011 | 01:57 PM
EscoVan's Avatar
EscoVan
Default Escort van injection timing
Hi need to set the injection timing on my 2000 1.8d escort van. any one done this before and is it just a case of taking the belt of and turning the pump a tooth at a time? thanks
Old Mar 22, 2011 | 02:33 PM
nellyscossy's Avatar
nellyscossy
no you dont take the belt off...unless you lock the engine with pins... there are bolts on the pump pulley that you slacken there is a small amount of movement to allow for adjustment
Old Mar 22, 2011 | 09:19 PM
As said locking pins/drill bits, 8mm from memory, easy as anything to do, all explained previously on pf threads, there is a book dedicated to the 1.6/1.8d detailing this also.
Don't forget if new to you, it might pay to do BOTH belts at same time.
Old Mar 24, 2011 | 08:44 PM
EscoVan's Avatar
EscoVan
Thanks for the advice did what nellscossy said and its perfect now
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
vdubo7
Aug 2, 2015 08:17 PM
