p38 rangerover help air suspension guru's
Old 16-03-2011, 08:27 PM
Doug
Doug's Avatar
Default p38 rangerover help air suspension guru's
just taken delivery of a p38 1997 2.5 dse air suspension is on the deck all lights flashing orange on suspension setting switch any quick checks that can be done to try and rectify ?
Regards Doug.
Old 16-03-2011, 08:32 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
what is displayed on the message centre
Old 16-03-2011, 08:33 PM
orionmojo
orionmojo's Avatar
if its like driving a brick i'll bet your air compressor has gone.
Old 16-03-2011, 08:35 PM
James
James's Avatar
www.rangerovers.net is a great resource for the p38.
Old 16-03-2011, 08:36 PM
Turbosystems
Super Moderator
more likely a burst air bag and or air leaks
air compressor wears out over working trying to pump up the planet due to the above
Old 16-03-2011, 08:39 PM
orionmojo
orionmojo's Avatar
fair enough. On mine it was just the compressor (i think). it just died (160k) .was fucking horrible driving it home again lol.
swapped it out and it lasted another 8000 ish miles til i sold it anyway!
Old 16-03-2011, 08:42 PM
Turbosystems
Super Moderator
lets face it all the parts if still original would be worn out lol
Doug
Doug's Avatar
Thanks for the replys nothing is displayed in the center display except usual windows sunroof not set
Old 16-03-2011, 08:48 PM
Turbosystems
Super Moderator
does the pump run first thing to do is :-
start the car in park,leave the drivers door open, open bonnet, lift off eas cover and check if the pump is running
Old 16-03-2011, 08:54 PM
Doug
Doug's Avatar
Thanks Tony ill check that first thing in the morning .
Regards Doug
Old 16-03-2011, 10:17 PM
fordsportjay
fordsportjay's Avatar
change it to coil springs!
Old 17-03-2011, 06:31 AM
stephenbatey
stephenbatey's Avatar
Did this to mine and it drives much better than with airbags.
Old 17-03-2011, 06:39 AM
Turbosystems
Super Moderator
none of mine are on coils but I have heard this a few times before. never tried one myself though
apparently you must notify your insurance company if your car is on coils
Old 17-03-2011, 08:19 AM
foreigneRS
Testing the future
foreigneRS's Avatar
while you're at it change it to a carburretor in case the fuel injection breaks and take the starter motor off and put on a crank handle. and change your wheels to solid wood in case the pnuematic tyres get a puncture.
Old 17-03-2011, 08:44 AM
Turbosystems
Super Moderator
sarcasm rules
Old 17-03-2011, 08:48 AM
Turbosystems
Super Moderator
doug you done check 1 yet
if pump isn't working leave it running and shut the door make sure all doors are registered as closed including the tail gate you can leave the bonnet open,the suspension should in theory now rise and the pump should operate
test one fills the air tank
next thrilling eas instalment will follow shortly lol
Old 17-03-2011, 09:08 AM
Turbosimpsons
Turbosimpsons's Avatar
yawn yawn yawn.
Old 17-03-2011, 09:20 AM
Turbosystems
Super Moderator
Originally Posted by a rs licker
yawn yawn yawn.
are you tired
mind you it is very early for you
Old 17-03-2011, 09:58 AM
arch
arch's Avatar
You can't buy a Rangey and put it on coils, it drives terrible. Sacrilege I tell ye, sacrilege. Its like a bald man saying that bald men are sexier, lies I tell you, lies.
Old 17-03-2011, 10:44 AM
david 100
david 100's Avatar
Welcome to the P38 club, EAS faults, as Tony will agree it cheaper to fix the air suspension than convert it to coild but please dont take it to a Land Rover dealer they will want Ł100 to open the workshop doors, take it to a independent 4x4 dealers or someone with a lap top that will read the faults.
Have you got the "max 35 mph " ont the dash with that annoying "beeb beeb sound coming from the dash.
Old 17-03-2011, 10:48 AM
Doug
Doug's Avatar
Originally Posted by david 100
welcome to the p38 club, eas faults, as tony will agree it cheaper to fix the air suspension than convert it to coild but please dont take it to a land rover dealer they will want Ł100 to open the workshop doors, take it to a independent 4x4 dealers or someone with a lap top that will read the faults.
hi guys thanks for inputs yes 35 displayed with eas fault
tony pump not running have powered it up and suspension still on the deck pump is presurising.
Regards doug.
Old 17-03-2011, 08:56 PM
Turbosystems
Super Moderator
you need to clear the eas ecu the suspension will do nothing whilst it is displaying the hard fault 35 mph eas fault .The eas is in lock out mode
you need some eas software ,the software you can down load for free but you need the correctly configured obd2 cable
Old 17-03-2011, 09:32 PM
andycos
andycos's Avatar
If you have a laptop,you can get the cable with software off egay.
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=p38+eas+c able&_sacat=See-All-Categories
Just make sure the cable software matches your comp operating system !
Old 17-03-2011, 09:42 PM
Turbosystems
Super Moderator
doug you need to check your bag get down and have a good feel and check round roflol
your air bags that is if they are the originals they are probably all fooked
Old 17-03-2011, 10:00 PM
steves24V's
steves24V's's Avatar
As said need to read and clear the faults, I have the cable and prog to do it not that i've used it in a while as mine have been ok for a while, too long really prob shouldn't of siad that.
Old 17-03-2011, 10:17 PM
Doug
Doug's Avatar
Tony you really are one sick puppy ! I've been given a set of bags lol and software coming tomorrow will try read and delete dtc's and will keep you posted
Many thanks Doug
Old 17-03-2011, 10:33 PM
Turbosystems
Super Moderator
Doug I think you have been sold a sick puppy lol
when your pissing around for ages with it doug make sure the battery is not discharged the ecu's in the range rovers don't take kindly to low voltage and low current they begin to have a pmt moment .Range rovers are power hungry with all their electronics
Old 18-03-2011, 09:28 AM
david 100
david 100's Avatar
Spray some soapy water on the bags and the pipes this will show any air leaks.
When you have replaced the air bags bags and tank will be empty, the compressor on a range rover is like a foot pump trying to inflate a tractor tyre, when you start the engine leave a door open this will stop the vehicle trying to pump up the bags and tank , it will just fill the tank, after about 5 or 10 minutes close the door ( leave a window open as when working on a range rover they have a habit of locking themselfs) it will then inflate the air bags.
As Tony has said a weak battery on a P38 can throw up a few problems so make sure you have 100 % good battery.
As for the vehicle locking itself it only does it if you messing with electrics like changing the battery but i dont take any risks, i never close the door if i dont have a open window of keys in my pocket, dont give up fixing the air suspension as its not that bad and there are a few owners websites that will give you lots of help, once you have a fault free car nothing can match it for comfort.
Old 18-03-2011, 11:04 AM
Doug
Doug's Avatar
For what ive paid for it Tony it was cheap !
Regards Doug.
Old 18-03-2011, 12:01 PM
david 100
david 100's Avatar
Doug its only a suspensoin fault you have and it could be a very cheap fault, you have what is called a hard fault, its on its bump stops and displaying a message on your display, get the fault read then you know what to fix, you will then have to have the fault cleared then she will pump up the suspension and away you go
Brickhouse
14
03-10-2015 07:28 PM
Johnny Knoxville
30-09-2015 07:21 AM
stevecfrst1
30-09-2015 05:18 AM
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: p38 rangerover help air suspension guru's
