Cossie Rear Suspension.. Normal??
Old 27-02-2011, 10:08 AM
  #41
R5FORD
R5FORD's Avatar
Nope beams fine the cars just undergone a year and a half restoration. So all looks good. If anything the wheel sits closer to the front of the arch so towards the door more
Old 27-02-2011, 10:10 AM
  #42
nugnah
nugnah's Avatar
well in that case i would put the coilovers back on, and put up with a slightly harder ride.
jas
Old 27-02-2011, 10:11 AM
  #43
R5FORD
R5FORD's Avatar
Thats not my style mate id rather just spend time figuring the problem out
Old 27-02-2011, 10:20 AM
  #44
nugnah
nugnah's Avatar
ok, so you are saying the one side is fine 'CORRECT', if so take the shock and spring off the good side and swap them over.
jas
Old 27-02-2011, 10:29 AM
  #45
B13 JUS
B13 JUS's Avatar
Is your arb ok?
I know my 3dr felt really bad on the back end with a 3dr arb so I've fitted one from a escort Cosworth
Old 27-02-2011, 10:31 AM
  #46
R5FORD
R5FORD's Avatar
What im going to do is take a koni of my old mans 500 and put it on the driver side of mine and give that a go.. Failing that il try organise a new rear beam
Old 27-02-2011, 10:32 AM
  #47
R5FORD
R5FORD's Avatar
Forgot to mention i have not got an arb but would that make a diffrence?
Old 27-02-2011, 10:34 AM
  #48
nugnah
nugnah's Avatar
i would think it makes a big difference with a non coilover setup yes.
jas
Old 27-02-2011, 10:35 AM
  #49
R5FORD
R5FORD's Avatar
In what way?
Old 27-02-2011, 10:38 AM
  #50
nugnah
nugnah's Avatar
well the ARB gives opposing force to side that is being compressed, so if the drives side suspension is being compressed, the twisting force of the ARB on the passenger side tries to help compensate the drivers side, not the best explanation but i think you know what i mean.
jas
Old 27-02-2011, 10:41 AM
  #51
R5FORD
R5FORD's Avatar
so in other words it tries to counter balance the other side? Would that still be the case when theres no speed involved etc?
Old 27-02-2011, 10:47 AM
  #52
nugnah
nugnah's Avatar
yes, as soon as any pressure is put on one side or ther other, the ARB automatically tries to compensate. even when slowly moving of a drive or kerb etc
jas
Old 27-02-2011, 10:50 AM
  #53
R5FORD
R5FORD's Avatar
jas
O ok so that colu be part of the problem
Old 27-02-2011, 10:52 AM
  #54
Turbosimpsons
Turbosimpsons's Avatar
have you got the spring rubbers on on both sides. i'd get the tape measure out and do some measurements. get it on level ground. (garage) measure rear arm to chassis both sides without shocks connected. they should be the same within a small margin.
Old 27-02-2011, 10:54 AM
  #55
R5FORD
R5FORD's Avatar
The car sits level at the rear on flat ground mate.. its when im backing out my drivewy or pulling in on full left lock and the driver side rear is the lowest point its going like that
Old 27-02-2011, 11:03 AM
  #56
nugnah
nugnah's Avatar
most uprated springs are uprated by 20% over standard, most coilovers are around 350pound rating which is alot more than standard, that is why the coilovers are able to deal with the lack of ARB.
jas
Old 27-02-2011, 11:08 AM
  #57
B13 JUS
B13 JUS's Avatar
If you have no arb on I think that will be your problem, you must be driving off your drive at a angle? So that puts most of the weight on one spring instead of the other size helping it out.
Also wouldn't bother fitting a 3dr arb because they are crap.
You car must feel very unstable at 80+mph? Give you steering a little left to right at 80 and see how it feels. Lol.
Old 27-02-2011, 11:20 AM
  #58
R5FORD
R5FORD's Avatar
I noticed that when i steer it does feel unstable even at low speeds and i couldnt pin point what the problem is/was just assumed it was tracking.
How hard isit to fit a escort one?
Old 27-02-2011, 11:21 AM
  #59
R5FORD
R5FORD's Avatar
jas
Makes sense thats probly why it never had one as it did have coilovers originally
Old 27-02-2011, 11:33 AM
  #60
R5FORD
R5FORD's Avatar
next question.. everyone says the 3dr anti roll bar is crap and dosent do anything how can this be the case if its doing this ti my setup?
  #61
Turbosimpsons
picture of said drive. it must be like the side of Everest. perhaps you need a Range Rover.
Old 27-02-2011, 11:36 AM
  #62
R5FORD
R5FORD's Avatar
its nothing major mate.. my saph used to get in nd out easily and thaw was lowered 30mm on 17's
Old 27-02-2011, 11:37 AM
  #63
R5FORD
R5FORD's Avatar
Il take the car out again tomoorow and do an all around shot of both sides so people can get an idea
Old 27-02-2011, 11:40 AM
  #64
B13 JUS
B13 JUS's Avatar
It's not to hard mate but the way I did it, you will have to drill 4 holes inside the boot to bolt the new arb in place.
I can give you measurements and pictures of how to do it if you like?
Old 27-02-2011, 11:44 AM
  #65
R5FORD
R5FORD's Avatar
send them by pm if you can mate then i can ask any questions etc?
Old 27-02-2011, 11:48 AM
  #66
B13 JUS
B13 JUS's Avatar
I'm at work till 6.30pm so I'll take some pictures tonight and explain what I did
Old 27-02-2011, 11:55 AM
  #67
R5FORD
R5FORD's Avatar
All good mate
Old 27-02-2011, 11:56 AM
  #68
botters
competant bodger
botters's Avatar
i wouldnt mind seeing that as well mate been thinking of fitting one on my 3 door
Old 27-02-2011, 11:58 AM
  #69
B13 JUS
B13 JUS's Avatar
Just thought.... I have saph trailing arms on mine.
the drop links are on the inner side of the arms unlike the 3dr, you would need to change or mod yours to fit a better arb as well as modifiy the fixing points on the chassis.
Old 27-02-2011, 12:00 PM
  #70
B13 JUS
B13 JUS's Avatar
I'll pm you with pictures and info as well mate.
Old 27-02-2011, 01:51 PM
  #71
Char1ie
Char1ie's Avatar
Old 27-02-2011, 01:56 PM
  #72
Char1ie
Char1ie's Avatar
Sorry, posted the last comment before I read that you don't have an ARB - the obvious problem.
Fit a 3 door or Sapph ARB. Escos I believe is too stiff.
Charlie
Old 28-02-2011, 03:55 AM
  #73
R5FORD
R5FORD's Avatar
I took my old mans ARB of his 500 to test to see if this would cure the problem only problem is the trailing arms are from a saph so wont fit Which has got me thinking that if the trailing arms are from a saph maybe the hubs are aswel? Is there any difference in hubs from a 2wd saph and 3dr? A im wondering now if my wheels are the wrong offset and causing some of the headache with the tyres rubbing the bodykit to bits? as they were to fit a 3dr and if the hubs are different could be causing a different offset?
So im trying to organise a ARB from a saph and get that fiited.
Old 28-02-2011, 09:34 AM
  #74
R5FORD
R5FORD's Avatar
bttt
Old 28-02-2011, 09:44 AM
  #75
fordsportjay
fordsportjay's Avatar
when you had the coilovers on you were not using the original springs in their mounts.
i would look to check the springs and that their mounting areas are the same and none have deteriorated or have anything in them. you really need to get the car on a flat surface to be able to establish exactly what the difference is either side.
Old 28-02-2011, 09:46 AM
  #76
fordsportjay
whoops...only read the first few bits.
didnt get to the antiroll bar bit before i posted
Old 28-02-2011, 09:55 AM
  #77
R5FORD
R5FORD's Avatar
All good jay. So people belive that the anti roll bar makes that much of a diffrence?
Old 28-02-2011, 10:06 AM
  #78
B13 JUS
B13 JUS's Avatar
yes 100%
in stead of having all the weight on one spring its spreads the weight across the two.
think of it this way... would your wheel still sit that low on your drive if your spring was double the lbs than what you have in already?
Old 28-02-2011, 10:09 AM
  #79
R5FORD
R5FORD's Avatar
yes 100%
valid point but in my mind i cant see me just fitting the ARB and this problem going away
Old 28-02-2011, 10:22 AM
  #80
B13 JUS
B13 JUS's Avatar
you wont know unless you try it, but what i do know if you dont have one fitted with the springs and shocks you have the car will be very very unstable to drive, it will be dangerous as well imo
Quick Reply: Cossie Rear Suspension.. Normal??
