Well thats the ST24 fucked...
Was running quite hot last night, even on a run with the heaters on.
and its making this loud ticking noise when you accelerate?
O well. Someones coming to look at it, and my other mondeo sold for Ł45 more than i paid for it 8 months ago
So all ive got to do now is find somewhere to live and ill be happy! and im going to look at a mk4 golf gt tdi 130 6 speed in a moment..
It drives ok tho? The oil/water hasnt mixed? Just runs a bit hot, and only makes that ticking when its warmed up? Gave it a good boot down the 45 into leam last night and when i got to maccies for a drink it was fluttering like a bastard when you rev it, sounds like exhaust is blowing at the manifold?
[quote=carlfiesta999;5350074]Was running quite hot last night, even on a run with the heaters on.
Sorry to here that you only just got it! what a fuck up ! bit hit and miss with these 6s mine done 108 thou and is fine no service history just got it and hoped all would be well done 9 thou from last year till now .
steve
Did a sniff test on it too and compression test well my mate did, i couldnt even locate the spark plugs.. and everything is fine? or appears so.?
Jst when its hot hot, it goes ticky ticky from like idling speed up to 3000 revs.. ?
We checked it when it was hot and cold aswell.. only a minimal difference. Well i wasnt there but my mate said its fine?/
you sounded hard up and i felt a tiny bit sorry for you until i read "and im going to look at a mk4 golf gt tdi 130 6 speed in a moment" get a place before the golf, a roof over your head is more important than a car
the tick you get where do you hear it from ? front, pullys,mid part of the engine the rear maybe? is it all the time upto 3 thou ? is it in sync with the revs?
im forever getting lambasted for telling people to fit the metal impellar jag pump ste, as it 'was only mk1's' that snapped the impellar apparently. i know ford did uprate the plastic in MK2's, but personally, i dont care what people say, both my V6's, this one, and my MK3, had a metal impellar jag pump fitted, and a brand new ford belt, the week i got them. prevention, is better than cure.
Its just upto 3k, sounds like drivers side of the engine? just going diesel next, getting too old to be crawling around under fucked old cars... should have seen me about an hour ago quickly touching up the rear arches on the other one with a rattle can before the new owner collected it
no not the ST, ive got too many cars, well did have, just the ST now.Serves him right for being rude to me on the phone the old tosser i had to do something with the rot before selling it, so mr p38 came out to play during the rain then when it stopped raining i quickly dusted them over, silver car so cant really tell, well until tomoro morning when daylight unmasks the horrors. he didnt even check it, he just looked round it, handed me Ł560 took the paperwork and went, 2000 reg mondeo zetec with high clutch and 1 months mot makes a change its usually me gettin fucked over.
Spelling Club King!
Highly likely it's either that or the exhaust manifold gasket. Both are a pig to do.
Gary Krishna
I've got a 2.5 ghia x as my runabout and this developed the tick a couple of months after I bought it.
Did all my underbonnet checks the other day and noticed the header tank level was low, took the cap off and loads of pressure still in there (the car hadn't been used for 3 days) and it smelt of exhaust gas!
It's had an oil leak between the rear head and block for a while so it's just progressively got worse and the car has never overheated at all (I've serviced the car every year since it was 2 years old and the water pump has been changed to the metal impeller type).
I'm just gonna use it until it packs up, it doesn't overheat at all. Threw some K seal in for good measure too!!
littlefluff
12-01-2006 10:55 PM
