Doing a clutch on a 1.6 Focus Zetec 2001
Going to be doing one this weekend. What's the job like? Is there much space to get the box in and out or is it a pain? Is the slave cylinder inside the box?
if its the saem as a 1.8 ecsept the starter is at the front
slave cylinder is inside the box
pece of cake u might need new ball joint bolts there common for cezing/snaping
really easy to do though plenty of room
and u dont hafto take the subframe off
Received 1,044 Likes
if the box is close to the sub frame use a scissor jack and put it in between the back of the engine and sub frame and wind the jack up till the gearbox clears the sub frame.
