Sponsored by:
Sponsored by:
18x9 on frs (NOW FITTED)
Old 13-02-2011, 08:07 PM
  #41
Dicko&Vacant
Dicko&Vacant's Avatar
rite just found this on rsoc site a post from dunccoss he has same wheels offset and size as mine are supposed to be lol
http://www.rsownersclub.co.uk/rsocbb...d.php?t=320228
Old 13-02-2011, 08:08 PM
  #42
Dicko&Vacant
Originally Posted by -beefy-
ouch ,
hope u get it sorted fella
how much they set u back ?
they owe me £500 beefy thats with cost of wheels and fuel to pick em up etc.
would look well on the s1
Old 13-02-2011, 08:14 PM
  #43
botters
competant bodger
botters's Avatar
can you not just get the arches pulled out a bit at a bodyshop? i remember seeing this done on a focus thread on either here or rsoc years ago he gained nearly two inch just dollying and rolling the entire arch out.
its quite a popular mod abroad to clear big wheels
Old 13-02-2011, 08:15 PM
  #44
wirralphil
wirralphil's Avatar
Ask Dunccoss to measure using the diagram I put up.
After that measure your brake bell thickness to determain if it different.
Are your wheels deffo 9 inch wide as it is from where the tyre bead sits is to determain the wheel width
Old 13-02-2011, 08:20 PM
  #45
RichieST
RichieST's Avatar
As above, to measure offset, put wheel on a flat surface, measure the distance between the ground and the mounting face of the wheel, subtract this number from half the width of the wheel. (all measurements in mm).
Old 13-02-2011, 08:22 PM
  #46
Dicko&Vacant
yeah mate deffo 9" wide ive already measured that
this is the one i used to check et
http://www.google.co.uk/url?sa=t&sou...n2t40GjfRw9Dew
Old 13-02-2011, 08:52 PM
  #47
COCHYN
COCHYN's Avatar
Deffo wrong offset if you're comparing with Dunc's or even the German Focus. Does it say ET35 on the inside of the wheel or anywhere else? Can't believe they'd make such a cock up and send the wrong set.
Old 13-02-2011, 09:01 PM
  #48
Dicko&Vacant
they have labels on them all with the size offset and stud pattern etc, dunc said on rsoc that they should be fine once tyre on and car on the ground.
Old 13-02-2011, 09:06 PM
  #49
rog24
rog24's Avatar
are you going to try that then and see how it looks?
Old 13-02-2011, 09:19 PM
  #50
COCHYN
COCHYN's Avatar
I wouldn't, very risky that. Especially with the rears not sitting correctly up in the air, in theory it should sit the same as the front. What if you chip them when putting tyres on? The front will deffo be the same when its on the ground, they stick out a good 10mm and the rears you'll need spacers to make them look anything like that German one.
Have you placed it on the ground and measured the offset?
Old 13-02-2011, 09:28 PM
  #51
rog24
rog24's Avatar
so has the german frs got different offset rear wheels to the front?
Old 13-02-2011, 09:52 PM
  #52
rs dub
rs dub's Avatar
agree with dunc here.my evo when up in the air make it look like the alloys are stuck out loads.but tuck in lovely when on the ground.i would give it a go.the et on my pr 1.2s are written in the backside of the rim edge.or just ring danny to confirm et
Old 13-02-2011, 10:13 PM
  #53
R5FORD
R5FORD's Avatar
will these fit a mk2 FRS ?
Old 13-02-2011, 10:30 PM
  #54
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
it would be worth fitting the tyres and dropping it on floor.
if theyve machined them wrong then regardless of wether youve fitted tyres, you are entitled to a refund/repair/replacement under your statutory rights.
After all, most people dont check the rims without tyres on the car and to be fair you cant be sure until suspension is normal height.
at least the ET is too low. easy fix to machine off more.
Old 13-02-2011, 11:11 PM
  #55
S1
S1's Avatar
You dont need to fit the tyres, If you place a jack under the lower arms as far out towards the hub as possible you should be able to get the full weight onto the suspension which will show you where the rims will sit under normal conditions.
Old 14-02-2011, 05:03 AM
  #56
rsturbowhite
rsturbowhite's Avatar
Nice looking wheels them dicko ! Got no advice on the of set but hope uget them sorted
As £500 sovs dusnt come easy
Old 14-02-2011, 10:15 AM
  #57
nugnah
nugnah's Avatar
looking at the pics, i woul dtend to agree, once you put weight on the front, the wheels will push in at the top due to the suspension set up
jason
Old 14-02-2011, 11:20 AM
  #58
Dicko&Vacant
Well I've gotta take a wheel to an alloy place today there going to check the et properly for me, then ill take it from there.
Old 14-02-2011, 01:14 PM
  #59
rsmark86
rsmark86's Avatar
pumaspeed do a rear axle widening kit rather than cheap spacers....
but as above you need the fronts machining to change the et... speak to touring car spares as they deal in them wheels and might be able to help
Old 14-02-2011, 01:17 PM
  #60
rsmark86
rsmark86's Avatar
speak to martin hadland at reyland hes the best guy on here with brakes and wheel off sets....
im sure he will be able to help
Old 14-02-2011, 01:27 PM
  #61
furry
DECODING JIBBA JABBA!!
furry's Avatar
now't wrong with a bit of width!!
Old 14-02-2011, 01:42 PM
  #62
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Had a look at your pics and you have exactly what I'd expect with a 9" ET35 wheel on a FRS. On a FRS the original wheel is an 8" ET42, I have supplied ET35 for a better look BUT that's on an 8" rim. By going ET35 on a 9" rim you add 1/2 inch more on each side compared with the 8" rim of the same offset. Your new wheels sit 20mm further outwards than the OE wheels, I think you either need to sell them on or flare your arch with an arch roller.
Old 14-02-2011, 01:47 PM
  #63
Alps Pacino
Alps Pacino's Avatar
just wind your coilovers right up at the front and set a new trend of reverse drag racing
Old 14-02-2011, 01:53 PM
  #64
Psycho Warren
Carbon Crazy
or get the wheel centres machined to sort out the offset
Old 14-02-2011, 01:55 PM
  #65
Alps Pacino
i prefer my idea
Old 14-02-2011, 02:13 PM
  #66
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
The standard wheel is 8x18 ET42, so a 9x18 ET35 has 6mm less inner clearance and protrudes 20mm further than a standard item.....
If you think it is the bell causing the problem, measure the thickness compared to a standard disc to see if this is pushing the wheel out further?
Old 14-02-2011, 02:30 PM
  #67
Martin-Hadland
Did you read any of what I wrote above?
Old 14-02-2011, 02:52 PM
  #68
Dicko&Vacant
You say that Martin but have you looked at the pics in dunccoss thread on rsoc? He's just put same wheel size and offset on his focus rs and it looks fine?
Old 14-02-2011, 02:53 PM
  #69
Dicko&Vacant
Mike I've tried the wheel on a mates focus with standard brakes and its the same as mine?
Can anybody give me an easy way to actually check the offset my self
Old 14-02-2011, 03:08 PM
  #70
Mike Rainbird
Caraholic
Did you read any of what he wrote, along with what Duncan has fitted to his car on the thread on the RSOC board?
Old 14-02-2011, 03:09 PM
  #71
Mike Rainbird
Caraholic
See the picture already posted on this thread (post 38) .
The only other thing I can suggest is to meet up with Duncan and compare wheels (or persuade him to take a photo of his with it jacked up like yours to see if the droop is causing some of the problem).
  #72
Dicko&Vacant
here is a pic of duncs car on same wheels
Old 14-02-2011, 03:21 PM
  #73
Martin-Hadland
As it happens, no!
Old 14-02-2011, 03:23 PM
  #74
robrs2
robrs2's Avatar
Dicko, did you have weight on the suspension?
Block of wood under rim, but not just on outer lip
Old 14-02-2011, 03:36 PM
  #75
Martin-Hadland
I know that when we tried an ET15 Monte wheel on Kelvs car it was so far out of the arch it looked stupid, so my comments are based on that really. Obviously an ET15 would (should) protrude 7mm more than your ET35 9" but it looked a lot more than 7mm as I recall. What is the measurement from the hub face to the back rim of the wheel?
  #76
Dicko&Vacant
No rob just had car lacked up?
Old 14-02-2011, 03:37 PM
  #77
COCHYN
COCHYN's Avatar
Its not going to be a problem with the bell, simple as. Its the offset on the wheel you need to determin, plenty of easy way to measure it. But its clearly wrong.
The German focus has a few trick details surrounding the suspension, and from what I remember also have spacers on the rear.
Old 14-02-2011, 03:41 PM
  #78
martynhomer01
martynhomer01's Avatar
stick a s2 rs turbo bodykit on it!!!!!!!!!!!!!!!!!!!!!
Old 14-02-2011, 03:46 PM
  #79
AndyKam
AndyKam's Avatar
Pictures of the German Focus out of interest??
Old 14-02-2011, 03:50 PM
  #80
Dicko&Vacant
bloody damn wheels
Sarah
Quick Reply: 18x9 on frs (NOW FITTED)
