18x9 on frs (NOW FITTED)
Well after seeing the german frs with the 18x9 pro race 1.2s i decided to get a set made off a lad off rsoc forum (his dad works for td)
I went for the exact same sixe as the german car with 18x9 and et35 picked the wheels up yesterday so had a trial fit today without tyres.
wheels
on the car
now the problem i feel like crying (real tears)
front which is the problem
rear
After looking back at the pics of the german car he only runs standard brakes, so all i can think is its the alloys bells on mine which sticks the fronts out?
any ideas please
wheels
on the car
rear
any ideas please
swindon rsoc
yeah but its all to do with the camber on the beam etc.... you might find once its on the deck the front camber angle may bring the fronts in slightly...? i know when i jack my saph up the back wheels come right out...
Tbh that top photo it looks like it's sitting out a good 20mm.out of interest,have you tried some of the other wheels on it just incase there's a difference?the car looks great with them on though.
You could extend the arches if that's your only option left,although that would be the most expensive route I'd guess,would look exceptional though!!!
Pity you hadn't got hold of another wheel in the same size/offset to trial fit before ordering (not having a pop lol) or maybe try one on someone's car with the standard brakes??.....i love the look of that german focus on the 9" rims but no one seemed to have actually fitted them over on the rsoc so being the first is a gamble eh
Do you think you could possibly return them and see if they can change the offset perhaps??
Do you think the fronts would fit with a different offset or are they just too wide?
couldnt return them as they were made for me in the size etc i asked for.
1 Post
Christ mate that's a mile out, but shouldn't think the bell is any thicker because it would still need to sit flush on the hub and you deffo would have noticed if the studs were shorter after fitting the brake setup.
Are you sure that's the correct ET? When I took that pic of the Focus in Holland, I didn't think to ask what the offset was, simply if it had coilovers on.
But I found out later that these are deffo ET35 all round, with 245/35/18 tyres and Bilstein coilovers with a 60mm drop. Also spacers fitted to the rear...
st170 breaking
would be awesome to get some new wings flared out a bit
shoudl be no hassle getting 20mm taken from the mounting face, ideal now the tyres is off to measure clearance to see if it'll go
or 2 slightly thinner wheels need to be put on order, keep the wider rears tho
is there anyway to check the offset is correct? i know all the wheels have the size and offset stamped on, surely if its the offset the rears would be sticking out also.
dunno what to do probs best off trying to sell them on.
The pics i took are of the same wheel i just swapped it from front to back.
Just been to a mates and tried wheel with standard brakes and its exactly the same grrrr so wheel offset must be wrong or that German one deffo ain't et35
rite ive just done one of them online wheel offset calculators things and i got it worked out the wheels ive got are et25, been in touch with the lad who had me the wheels made and if they are wrong they will make me some more.
going to take wheel to a tyre place and see if they can work it out properly for me.
