Mk6 rs2000 immobolizer
Fife Radge
1 Post
ive got a toad alarm and imob fitted ot my car but sometimes its wont disengage so i have to bump start itto get her going. Anyone any ideas how to disconnect the imob
I don't quite understand that ?.If the immobiliser circuit is still broken ie coil/fuel how would the car start even by bumping if the alarm/immobiliser had not disarmed ?.Unless its only the starter circuit that been interrupted by the alarm.In which case is your starter any good ?.
Fife Radge
1 Post
ill rephase that basically you press the button to unlock/disarm it. theb light goes green on the dash and its starts. but sometimes all you get is the dash lights and it doesnt turn over
That being the case you can always get your trusty digi meter out and check the power away from the iggy switch when you turn the key(after removing cowling), then see if the immoby for the starter is before or after the iggy switch and work out whether this is causing a stop, 99.9% assure you it's not the toad, at fault.
Fife Radge
1 Post
you get all thelights but its doesnt turn but sometimes you can hear the strater click but its doesnt turn over. think its the starter or the cables just needto find out where to get them
Fordmad!
15
27-09-2015 06:24 PM
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
Vacuman
22-09-2015 12:09 PM
