megasquirt sensors
Glasgow Rangers
anyone know if you need both a tps and a map sensor for a turbo application with megasquirt ecu.
ive read you need something that senses engine load and wondered if only the map sensor would do this, and what the tps is needed for
cheers
cheers
Glasgow Rangers
so i take it : load = when driving the car
and : acceleration = car basically still and reving the engine
or im i still getting confused.....?
Balls Deep!
Any time you press the accelerator pedal the engine takes a big gulp of air, if you do not give it enough fuel to match this the car will 'hang' for a second and jerk as it will be lean.
You use the TPS to tell the ECU that you have pressed the pedal and how fast/far you have pressed it, the ECU then gives the correct amount of fuel to prevent the 'hang'.
NA applications can use the MAP sensor to sense the throttle being opened (MAP increases) but for turbo'd applications the MAP can vary too much on boost and your AE will be cutting in when it should'nt be
![](https://passionford.com/forum/images/smilies/smile012.gif)
there's a lot to take in mate. lol! I get info overload when I start reading it, and I've been a technician for 15 years (hgv). there's some easier to digest guides on www.extraefi. co.uk. worth a look.
Glasgow Rangers
good drawings on there.
it seems you could spend half your life learning about megasquirt, but its very interesting stuff.
there should be a couple base maps knocking about for zetecs but I wouldn't use them as gospel. I'm gonna start from scratch with mine. the hardest thing I'm finding is the spark maps. fueling Seems fairly straight forward. oh and the idle pwm is a shit too.
Turbo obviously you need a map sensor, ecu or seperate, and tps otherwise on n/a it can be mapped purely on tps and cts, for racing etc, not nice for a road car.
In short use any sensors you have input for for a better drive.
MS is has a built in MAP sensor, use the existing TPS, then Calibrate AIR TEMP Sensor and COOLANT TEMP sensor.
Then map the Mofo, when I MSed my 24v Sierra, I found a old ecu, cut the connector out, and made a loom.
This is it when I sold it
![](http://img.photobucket.com/albums/0703/johnnyb/IMG_2297.jpg)
have a word with dale at baileyperformance hes got a load of diffrent mapps for difrent engines and that and he's spot on,mapped mine for me in a day
how much the map knock you back mate. was looking at them to maybe do the finalising of mine once i got it so far. see how i get on first.
Mark RS
12-10-2015 06:01 AM
