mg zs lumpy when cold UPDATE
Old Feb 3, 2011 | 06:18 PM
fiestaturbo1984's Avatar
fiestaturbo1984
Default mg zs lumpy when cold UPDATE
been offered a 1.8 for dirt cheap with t&t, headgasket not long replaced, serviced in dec. been told it idles bit funny when cold. any ideas on a likely cause? coilpack maybe?
Old Feb 4, 2011 | 07:13 AM
Could be a few things, even the cts, ring 01953 456000 and ask for richard, he does nothing but these cars all day everyday, so knows them inside out, he talks a lot(think he's lonely, or gay ha ha!!) but will help out.
Old Feb 4, 2011 | 07:59 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Check inlet manifold gasket on cylinders 1 and 4, well known to let coolant into the pots. Have a look at the colour of the plugs compared with each other.
Old Feb 4, 2011 | 08:41 AM
fiestaturbo1984
cheers, going to have a look at it shortly, its put engine management light on if thats of any relevance
Old Feb 4, 2011 | 09:46 AM
carlfiesta999's Avatar
carlfiesta999
Its one of the sensors, mine did it on my ZR, cant remember which..diagnostics will tell you, once its warmed up it should run fine
Old Feb 4, 2011 | 02:50 PM
fiestaturbo1984
well, i bought it. very happy for what i paid. as for the symptoms, from cold it drives fine and when up to temp it still drives fine however a couple of times on the way home when accelerating it hesitated, sort of like a miss-fire. any ideas?
Old Feb 4, 2011 | 03:02 PM
RichieST's Avatar
RichieST
Have you read the fault code?
Old Feb 4, 2011 | 03:12 PM
fiestaturbo1984
dont have any way of doing so,no diagnostic eqpt
Old Feb 4, 2011 | 03:18 PM
RichieST's Avatar
RichieST
On my mate's rover it's got an LED on the ecu which will flash a certain number of times to give you the fault codes.
Old Feb 4, 2011 | 05:07 PM
Martin-Hadland
THat's an old Honda engined car, the Rover ecus didn't have that facility.
Old Feb 4, 2011 | 05:55 PM
fiestaturbo1984
gonna find somewhere that can put it on a diagnostic see if that gives me any clues
Old Feb 4, 2011 | 06:04 PM
jamie's's Avatar
jamie's
if its missing under load prob a coil pack
very common on these
Old Feb 4, 2011 | 06:15 PM
fiestaturbo1984
yeah thats what i was thinking, doesnt do it all the time, only about 5 times in the few hours i have been driving it
Old Feb 4, 2011 | 06:52 PM
as355f1's Avatar
as355f1
I would put money on inlet manifold gasket, commen as fook and cause a missfire when cold
Old Feb 5, 2011 | 01:46 PM
fiestaturbo1984
ok so i have been to my local motor factors and so far i have changed both the coil packs.not driven it yet but the eml is still on,does it need to be reset or is it the same as my old 620ti with a self learning ecu which adapts after a few miles. i have also ordered a inlet manifold gasket which i will change aswell to be in the safe side
Old Feb 5, 2011 | 02:17 PM
fiestaturbo1984
well ive taken it out for a drive and on the 20 minute drive it done it again about 4 or 5 times so its not coilpacks
Old Feb 5, 2011 | 02:59 PM
st3v3's Avatar
st3v3
seems to me like youre pissing in the wind without the fault codes being read, for the price of two coil packs you could have got that done now.
Old Feb 5, 2011 | 03:04 PM
fiestaturbo1984
its not the end of the world with regards to coilpacks, i can get refunded on those, its trying to sort it now when garages are closed
Old Feb 5, 2011 | 03:16 PM
RichieST's Avatar
RichieST
As above, there is a light on the dash waiting to tell you what the fault is. Get it read first, then fix whatever needs be
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
