Faulty abs sensor
Faulty abs sensor
Is there any way of finding which abs sensor is faulty on my saff cos without the hassle of changing them 1 at a time?
Thanks Billy
Thanks Billy
Don't mention ze Vor
Unplug the plug that goes into your ABS ECU behind the dash. You can then measure sensor by sensor at the respective terminals of the plug. Have a look at a wiring diagram to see which is which. Or if you can take a photo of the pins of the plug I can mark them for you.
Best to measure voltage (AC!) which should be 0.1 - 0.2V when rolling and about 0.5 - 0.7 at 25 mph. You can either do it while a mate is driving or jack the car up, turn each wheel and note the readings.
Last edited by PeterRST; 01-02-2011 at 11:53 AM. Reason: edited to avoid misunderstanding
WHEEL SENSOR TESTS
All tests performed with ABS ECU unplugged and ignition switched OFF unless stated otherwise.
Sensor Resistance Tests
-- Connect ohmmeter as described:
-- If value is not correct, unplug each sensor (in engine bay or under rear seat) and check sensor for resistance between 800 and 1400 ohms at sensor connector. If sensor resistance not OK, replace sensor. If sensor resistance OK, check wiring for continuity between sensor connector and ABS ECU connector.
Sensor Voltage Tests
-- Connect voltmeter, set to measure AC volts, as described:
-- Correct result is voltage between 100 and 350 mV for the front sensors and 100 and 570 mV for the rear sensors
-- If value is not correct, check the sensor installation and the toothed ring condition
Sensor Cable Shielding Tests
-- If value is not correct, inspect cable insulation and repair
- for RH rear sensor, connect ohmmeter between ECU connector terminals 4 and 22
- for LH rear sensor, connect ohmmeter between ECU connector terminals 6 and 24
- for RH front sensor, connect ohmmeter between ECU connector terminals 7 and 25
- for LH front sensor, connect ohmmeter between ECU connector terminals 5 and 23
- for RH rear sensor, connect voltmeter between ECU connector terminals 4 and 22
- for LH rear sensor, connect voltmeter between ECU connector terminals 6 and 24
- for RH front sensor, connect voltmeter between ECU connector terminals 7 and 25
- for LH front sensor, connect voltmeter between ECU connector terminals 5 and 23
- for RH rear sensor, connect ohmmeter between ECU connector terminals 1 and 4
- for LH rear sensor, connect ohmmeter between ECU connector terminals 1 and 6
- for RH front sensor, connect ohmmeter between ECU connector terminals 1 and 7
- for LH front sensor, connect ohmmeter between ECU connector terminals 1 and 5
Received 1,044 Likes
can you not just disconnect the abs sensors then use a multimeter to check to see if there working when yet spin the wheels. Is the abs light going off when the car is stood stationery?
But it's easier to do it on the multiplug leading to the ABS control box, than having to access the sensor connectors under the rear bench/ in the engine bay individually.
have you checked things like the fuses and relays. My abs light was on the other week from starting the engine up. This was cause of a poor connection. Can you hear the relays clicking after the engine has been started
When I push the brake pedal the red brake light flashes on for half second and I can also here a click coming from near glove box Wichita sounds like a relay
OK, so perhaps not the usual suspects.........
What exactly is the issue you've got ? So far from this thread, it seems that the orange ABS light comes on immediately when engine started and doesn't go out, and the red brake warning light always comes on after brakes applied. Is this correct ? Any more symptoms ? Do the brakes actually work OK ?
G66UES+D89XVX+R18FMCPilot
if a sensor is totally shagging & copper windings inside have broken down then that will put the light on
if the sensor is on its way out sometimes when you start the car it does its system check & if everything is ok it will put the light out but when you start driving the sensor that is braking down will start losing its signal & cause a brake in the circuit & bring the light on
also a common 1 i,ve seen a few times it the 2x multiplugs on the resevoir the 3 pin is the brake fluid level warning light that does the light on the dash the 2 pin plug is the brake fluid level warning for the abs ecu, unplug the 2 pin plug & check both electical pins are where they should be as i,ve had one that 1 pin had dropped back into the rubber boot so wasn't making contact as soon as i bridged them it turned the light out & stayed out & abs worked fine
hope some of this helps
I wondered if anyone would pick me up on that.
I agree, it could be a sensor fault, but from the problem as described so far then a sensor fault wouldn't be my prime suspect. Of course, if it had been reported that the light had previously come on when the car was being driven and now comes on all the time, I'd agree it's most likely to be a sensor.
the red brake light comes on for split second then goes out when the pedal is pressed
the brakes work fine but i have no abs
fluid level is ok
if the abs wasn't working would it over pressurise the system? reason is i was told if you pump the pedal on a cossie the red brake light flashes on. i used to get the red light flash on when sitting at traffic lights and keep putting my foot on the brake. i asked on here and was told that all cossies done that
sideways all the way!
can i dive in on this...
my car puts the light on as soon as you start it and it never goes out,the red handbrake light never comes on,but myabslight flickered a few times before it stayed on permanent,i have had the resevoir changed though so ill check them plugs because the problem started after this had been changed.
any more ideas what can do it,mega ballache come mot time.
I have tested the rear sensors and at 25mph there is no voltage reading at all and a very low ohm reading. I also tested the fronts but i don't think I was spinning the wheels fast enough as I got no reading for anything on either
Actually it could be an abs sensor, the whole system has to be a complete circuit for the light to go off & stay off,
im having problems with mine.Im.wondering if ive got a faulty sensor.Ive got a spare front one and 2 back ones.I will have to try to swap the sensors.
