FAO Carlo or BMW folk!!
I havent used my M5 (E60 Model) for a while so found it had a flat battery, so i jumped it as said in the manual and have found the airbag and seatbelt light stay on with a red airbag light in middle and a warning on the idrive say airbag safety restraint system faulty......never had this before! My odb code reader says there are no faults so i cant reset...any ideas before i go to the stealers lol??? I read in america the airbag system has a 10 year warranty but not UK after speaking to my local stealer.
it will be due to undervoltage mate seen it happen a few times charge the battery fully ! you will most likley have to have the lights reset at bmw we would charge £60 + vat for this. Also because the battery demand is high on these cars sometimes the heated rear screen etc might not work they shut all the high drain things down so the engine managment has as much power it can get for as long as it can get to keep the car mobile.
Have you fitted a new battery or just jump started it? The batteries are a cunt to get to if there anything like the ones we have here (underneath the relays, amp etc..) and as Carlo said, it'll need registering that it's got a new battery
Resident Wrestling Legend
it really is something when you have to register a battery to the car
what next? you've got to be wearing corporate bmw merchandise in order to drive one?
they can't fix their indicators but batteries that won't work until they have been programed to the car, well
Dojj you have no idea with bmw we cant fit a part under warranty untill the diagnostic test plan tells you to , you also need to write a diagnostic code down & most cars now for missfires you dont put a spanner near them they get reprogramed first with the latest version , that most of the times writes the missfire out or such likes ! then you start replacing parts. They are so complex now its not true i petty anyone that serves their time in a back street garage & has to come into a bmw dealership it would be a whole new world to the best of tech's. Even tho you know whats wrong with the car untill the computer tells you in black & white you cant replace anything .
saying that, my transit is at ford because it needs a software update to sort the hunting at idle, but how the van knew it needed an update and starting playing up, i have no idea
I think it's pretty bloody terrible really about things such like registering a new battery with the ECU. Just leads to massive over-complications which can only be sorted by main dealers. Give it a few more years and there will be no such thing as an independant 'back street' garage IMO.
Testing the future
is it such a bad idea that vehicles will need to be worked on by properly trained people, rather than any charlie with a set of spanners? ok, you can go too far with certain things that are only setup by the manufacturer to make sure that their dealer network is looked after, but there is a european law that says that independant garagres are entitled to get the same tools as a franchised dealer.
It's at 117k miles so we've got to pay for it, might ask hinge to look up what they did to it if they don't give me a few sheets of paper to tell me what they are billing us for, £120 for "exploration work" and I said "it's not like you are going to be drilling for oil is it"
...yes it fucking is....but i had to tell the BMW workshop bloke it needed a reset to clear the lights and that it had to be registered..."oh ok hope thats the problem then"
CARLO. (or any BMW techs) I need your BMW technical advice here. I was thinking of buying my other half an older style BM just to get her to work and back. I was thinking of a 2001/2 3 series, probably a 4 pot, or a 2.0 s/six if I saw one at the right money. Do these year cars have the same issues with the dealers?
The valvetronic 4 cylinder engine is a bit of a pain in the arse if it goes wrong ! they have eccentric camshaft & electronic valvetronic motor we have seen loads with wear on the shaft causing missfires etc but no cheap fix i wouldnt go near a valvetronic ever ! the 6 cylinder is far better imho hard as nails.
years ago one of our vito's blew off it's intercooler pipe
30 seconds to put hte pipe and clip back on, nearly an hour to clear the fault codes
there is a boost leak
there is not enough fuel pressure
there is too much air
the injectors aren't opening
it's in los mode
etc
it's in los mode
etc
*** Sierra RS Custard ***
Is it a VRLA / Dry / Spiral Cell battery Phil?
If so I believe you should be able to register it ok, but if its a normal lead acid battery then you wont.
You can get a tool to chat to the on board diagnostics but Ive not personally used it so cant comment on how well it works:
http://www.bavariantechnic.com/buy.aspx
