Expanding foam in the exhaust...
Hypothetically speaking of course:
What would it do?
I mean if you cranked it over (or tried to) - it obviously wouldn't start, but??
Tom
What would it do?
Tom
Lets say for arguments sake it aint coming out - the stuff will stick to a loose and dusty lime mortar wall, so 6" of it isn't going to be forced out of a pipe in a hurry...
Tom
Tom
Try it with a potatoe you'll see what happens.
Starter? Gaskets?
Tom
Turbocharging Technician
i think it would blow the silencer to bits, igniting the fuel tank, blowing the roof off the said car,sending seats and interior flying, knocking it into gear sending it through the hedge into the nearby fields, taking out cows and sheep in the passing, ending up in the river, drowned with bent con rods IMO
some bloke did it to his e30 318 beemer, it ran for about 2 mins with throttle pinned then cut out and wouldnt start again, probably bent a rod or somethin!
They have ;0
Tom
what would happen then?
In that case, due to the enclosed environment of the exploding exhaust the vapours created by the fuel tank rupturing would be contained within the built up area, creating an ideal "stoich" explosion, flattening your house and all its surroundings, taking out your pet rabbit (yes yet more animal death im affraid) not only that the gas main would be ruptured, creating a second, bigger explosion, very similar to Coronation streets disaster of late, on a bigger scale to what happened in Emmerdale, and with less fit birds than hollyoaks. IMO
feet found, i have 2
Chaffe your replys are
As for the topic go and put your hand over the exhaust,once the gas has no escape it will simply stop.If it was blocked partially say a collapsed cat it would struggle,blockage no go.My lad flipped his bike the other week and after 5 minutes of watching him trying to kick it up I wondered over to find the rear can blocked with mud.
If in Doubt Flat Out...
say for arguments sake it happened to a lad around our area who had given a mate of mine a pasting when he was on his own and the guy had 8 other people. It was a better idea for us/them.anyone to drill a small hole underneath the where the exhaust met the manifold and leave the nozzle on an open can to fill up both the zust and engine. for arguments sake.
Resident Wrestling Legend
when it gets hot enough to burn, it don't half stink
but it would be much easier and more fun to simply discharge a canister into each of his wheels, just point the pipe into the inside of the rims at the top and then, if you are lucky, not only won't the car move, it will also be glued to the floor
Testing the future
all that will happen is that it will not run as insufficient oxygen will be ingested, and the spark plugs will probably get too wet. remove the restriction and after drying the plugs it should run again.
if the engine could keep turning over and not stall id say the head or manifold gaskets would go first
a little hole in the tyre to fill with foam to?
155lee
24-10-2015 11:11 AM
Johnny Knoxville
30-09-2015 07:21 AM
